Leveling question.
T
Tractoman
How did it ride with the stock springs and the bilsteins?
It rode OK but the springs had 84K on them. The reason I replaced them is one had a small 3" piece broken off the end of the coil where it allows the spring to wrap around the perch. The new ones feel a bit stiffer but not harsh at all. Feels better to me and since I tow a boat, prefer something a little stiffer anyway.
NGAneer
NWGA
So, save for the towing and broken spring, you would've left it? One other thing because I may have missed it, did you have ZW7 smooth ride suspension before?
T
Tractoman
Yes, I do have ZW7 but not self leveling. I would have left them if not for the broken spring.
NGAneer
NWGA
10-4, appreciate it. This goes against the general rule that the ZW7 has to have springs replaced if going to Bilsteins. Any pics of the truck with the shocks in but not the new springs?
T
Tractoman
The after pick at the top of this thread was after the 5100's front and rear, but before the new rear coils. I discovered the broken rear coil when installing the rear spacers of the CCM kit. This pic is with the new moog coils.
NGAneer
NWGA
10-4, thanks brother. Truck looks real good btw.
...I tow a boat,
How does she sit with the boat hitched up, any sag?
I believe this is because folks equate the ZW7 suspension with the Nivomat shocks. It is RPO G69 that specifies Nivomat shocks which are used with softer springs. ZW7 is a basic, traditional, plain shock and coil spring set up, no leveling of any kind.
akram
