How to remove rear vent cap appliques?
Cattivo
The Concrete Jungle
For any other barn door guys out there looking to do this mod...they fit no problem. Took me no more than 10 minutes to remove the old caps and install the new vent caps :thumbsup:
Zumwalt
El Paso, TX
just jumped in on this conversation, what tail lights are you running on the barndoor model? @Cattivo Also what year caddy vents will fit the 03 tahoe?
Cattivo
The Concrete Jungle
These are the LED tail lights I have on my barn door Tahoe...it's a pretty easy mod, all you have to do is remove the part that interferes with the bottom hinge of the barn doors. I recommend using a dremel with a cut off wheel. You can get a better idea of what I mean if you want to look on page 5 of my build thread
2000-2006 GMC Yukon Denali XL Red Lens LED Tail Lights Brake Lamp | eBay
I believe any NBS Caddy(2000-2006) rear vent caps should fit your 03 Tahoe brother...someone please correct me if I'm wrong
05Single
afraid of the dark
No one will correct you, cause you is right. All years fit all years, fit all models.
(Except that caddy is 02-06)
Crcz71
Anderson SC
Know this is old but is there an easy way to remove these things? I’ve got my esky vents ready but I have jerked pulled cussed and cannot get my old ones off. I even took some rope threaded it through the vent to use as a handle for some leverage and nothing. I don’t want to destroy mine but I’m to the point of cutting them off and then getting the tabs behind the glass out.
treehan77
TYF Fiend
Crestview, FL
Unscrew then first then yank them off.
Jordan0277
