JL Audio Stealth Box!
yukon702
Las Vegas
I gutted the whole bose system. I put focal performance speakers all around with JL amps. JL amps IMO are top notch, the specs, the true rms output and they last forever. Even JL subs are great but i just didn't like the stealth box. I'd get the JL amp even off of Craigslist, it's rare to hear of one going bad even the old ones
Sent from my SM-G928V using Tapatalk
Msalinas408
That is the best speaker and amp combination you can have. I have a pair of Focal Utopia's in my front doors and a pair of Focal PS 165V1 in the rear. Both are powered by a JL Audio HD600/4. I had them connected to a Rockford Fosgate at first and then I bought the JL. The difference between the sound is night and day. JL is a much more higher quality amp and sends such a clear signal even at high volume. Love this setup so much!
TechSupport
TechSupport
Stock radio?
yukon702
Las Vegas
Exactly. Perfect combo. Friends, family are amazed when they are in my suv. It's like being in an orchestra lol
TechSupport
TechSupport
A small update. Yes the JL stealth box does fit. No it doesn’t take just an hour like they say. The instructions are for a Tahoe. In the Escalade you have to remove dash panels to remove the center console. Right now I have it running off the stock Bose amp I didn’t have the time to run my 500/1 and I wanted bass still.
C56FC603-6F72-4658-A97E-BBB19FAA3FEB.jpeg 3A50EF7E-E224-479B-867E-B8AAC866BABD.jpeg A6AF4B77-4AA2-4855-BA54-9EF469AEA097.jpeg A81C3C2C-A81C-4EC8-A848-61A84E3539F6.jpeg
Unit171
NC
Where are you pulling your signal for the LOC?
TechSupport
TechSupport
With the JL amp you don’t need a LOC. I used The JL Audio XD CLRAIC2 SW. it’s basically rca to speaker wire and attached it to the sub output from the Bose amp. The JL 500/1 is way too big for that sub so I have the gains all the way down. With the gains turned down the signal sensing doesn’t work as well as it should so I went to the 12v outlet that’s on back of the center console because it’s switch for the remote turn on. I was surprised how hard that sub hits. I may end up installing a LOC to Fine tune the bass a little more.
Pops McGee
NJ
I'm having two JL 8W7AE-3's with JL HD900/5 installed next week in my '16 Tahoe. Subs are going in custom box where 3rd row is and upgrading door speakers. Will post pics after. Stock radio with a line output converter. Either JL or Audio Control
tnorman1
