Issues after oil change, tranny flush, diff fluid change, and all brakes...
GranPrix
So today I dropped the oil plan for a cleaning and oil change, dropped the trans pan and flushed it along with a new filter, changed the diff fluid along with a cover cleaning and changed all four rotors and pads. Now I have the check engine light on, the traction control light on and it's also telling me the stabilitrac and traction control is not working.
Now after I did all this maintenance I'll be driving anywhere between 0-60 mph and my revs will slightly jump and drop back down, a small acceleration on it's own.
In addition to this about a month and a half ago I cleaned out my TB and to this date the relearn process has yielded negative results. I still get a small surge of power as I come to a stop.
http://www.tahoeyukonforum.com/threads/idle-relearn-throttle-body-cleaning.99423/#post-1195435
could be a ABS sensor, check all your work, make sure you didn't yank a sensor wire out, do you have a scanner that does ABS?, if so run a scan and see what sensor is out
GranPrix
GranPrix
So I ran the scan on it,
P0102:
Mass or Volume Air Flow Circuit Low Input
P0113:
Intake Air Temperature Circuit High Input
Cleared them and we're good now. I just remembered I removed the intake tube to flush the trans hence the codes! :banghead:
But I still have the stabilitrac and traction control going off
GranPrix
GranPrix
WOW I’m an *******, I never reconnected the MAF plug. Now the stabilitrac and traction control warnings are gone but the check engine light is still on.
Now here’s where it gets interesting. With the codes cleared and the plug unplugged the power surges were gone. Now that the plug is back in I’m getting the small power surge again
HiHoeSilver
Away!
Chicago
Did you clean the MAF with something?
Tinkerer4
