Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
Chrismnj
Chrismnj
NJ
update it took about 1 hour for the install.
Chrismnj
Chrismnj
NJ
what does that can do? is it really necessary? or its just for modified engines?
An oil catch tank (oil catch can) is a device that isfitted into the cam/crank case ventilation system on a car. Installing an oil catch tank (can) aims to reduce the amount of oil vapors re-circulated into the intake of the engine.
Is the catch can necessary?. I think you just started WW 3 with that question LOL, depends who you ask.
a far as the last part of your question you can install catch can on any car/truck modified or not.
kbuskill
NE. FL.
Just pulled a trigger on these items. Seriously considering headers now, any suggestions?
Just FYI... the TB spacer is a waste of time and money on these engines since they are not TB fuel injected. The injectors are down stream so it has no effect on fuel atomization like the older vehicles.
Also... BBP did dyno tests on a bunch of intakes and concluded that the best power per dollar came from just changing the intake tube to the MIT and keeping the stock (cold air) box.
Not knocking your choices just trying to help you save a buck.
Ta6112
