kbuskill
Are the spindles aluminum as well?
That would drive me crazy... Seems mis matched. I'm sure it works the same, but I have OCD
Yeah that would drive me crazy too.front suspension parts came in...kind of annoying the upper control arms are "different". ordered same part, same product line, consecutive part numbers.
one comes in with a black boot on the ball joint and the other has a blue cover. one finish is smooth the other has the rough cast finish. there really isnt anything on either to identify wtf it is so I dont know which one is the right one.
also parts are wayyy lighter than the cast iron (not steel!)
@RockAuto maybe you can help?
see pics on next post
yep theyre aluminum...there "may" be a steel ring that goes on the inside where the bolts for the wheel bearing bolt to, i've seen some spindles with them and some without trying to find out if theyre needed and where to get them
you n me both... if they were the same i wouldnt care which way they came. rockauto is great with returns but i dont even know which one to return in hopes of getting the replacement that matches the other
GENIUS!Order a whole new set return 2
