Sometimes it starts. Sometimes no start
Randy74
I have a 04 suburban Z71 4x4 with 130000 miles on it or close to that. I have had several issues with this vehicle since we bought it. My problem i am dealing with now is what the title of this thread states. The vehicle may sit for a few days between uses. One time I got in the sub and drove it to a local ice cream shop. Started with no problem. Drove about 5 or 6 miles shut it off, orderd food went back to it and no start. Lights and everything else worked. Jumped it and it started right up. Happed again a week later when the wife took it to get gas and it would not start at gas station. Any help would be appreciated!!!
Thanks
Sent from my SM-G973U using Tapatalk
wjburken
Eastern Iowa
Thanks
When you say “no start”, do you mean it will turn over but not start or it won’t even turn over?
first have your battery tested, if the battery is good then
throw a hammer in the back seat, next time it wont start grab that hammer and tap on the starter housing a couple times and see if it starts then, if it does then that is your likely culprit, what you are describing is typically a starter issue, but you should confirm first, don't just run out and buy a starter.
Sounds exactly like an issue that I had with my Yukon. @Doubeleive gave you great advice on what your next step should be.
I ended up replacing my starter, which I purchased at Rock Auto, and I've never had the issue since then.
Super Moderator
Elev 5,280
This needs to be answered. Is it a "crank, but no start," or "no crank?"
The positive and negative battery cables are known to rot from the inside out, so jumping the battery may be moving them enough to make a better connection.
R
Randy74
Everything works when the key is on but when I try to start it it just clicks. It does not do it all the time. Thats why I am baffled.
R
Randy74
I will test the battery. The battery is only a couple of years old but that really does not matter.
Garage2010
