pwtr02ss
Tennessee
If I'm going to do this updated valve cover, what all would I need? Would the new cover come with a new gasket? Anything to clean inside?
I don't really want to tear into this as it's my daily and can't afford to be without it. I'm ok with cleaning inside and parts, but really replacing other stuff is not on the priority list.
Sent from my Pixel 3 using Tapatalk
I bought a gm one off rockauto. It came with everything including bolts. Part 12570427
Feeling like a failure everywhere else in my life at the moment, I decided I'd do something "big" (to me, anyway) to actually feel accomplished. The Universe gave me a big "**** you".
I attempted to do some small and harmless changes to the Tahoe's tune to pop my "change and write" cherry. To correct my 1-2MPH speedometer discrepancy, I measured the tire circumference by duct-taping speaker wire to the concrete and backing over it, then wrapping the wire around the tire and marking where the end met. I corrected the number in HPT (18mm difference). I then unchecked the boxes for anything relating to the EVAP codes. I tried writing those changes I made to the tune and it prompted me to apply my credits. I purchased two a long time ago since HPT's site and EVERYONE else said it takes two. It gave me the option to tune the ECM (requiring two credits) and/or the FSCM (requiring one credit). I checked the box for the ECM and checked "Do not license" for the FSCM and tried to continue. Apparently, unless I'm misunderstanding what I found on HPT's site, it's too late. It's like HPT has already applied my credits/licenses to a vehicle that has that extra module and it won't let me proceed until I buy an extra credit. I thought maybe I could just re-read the current tune but uncheck that FSCM module, make my changes, then try again. I don't know. Maybe I'll try again next month after I cool down. I was too pissed to find that surprise so I moved on to trying to log some scans. Tried a test one with it idling in my driveway and I swear I saw it say it was saving the file as "scan..." after I clicked the "stop" icon. So, thinking it was just that simple, I went out to the highway to log a WOT 0-100 hit and a WOT 50-80 hit, clicking "stop" and "start" between each. Feeling accomplished, I went home and found that the only file saved is the "SAMPLE" one that it comes with.
So, now I'm ready to break shit and post an very slightly used MPVI2 for sale.
89Suburban
Bull in the china shop
SE PA
I feel the same way
lol, sounds like me trying to log some stuff in EFI live with the autocal connected my tablet, can't made heads or tails of that shit :shrug: I can find the screen that should show the transmission data but can't figure out to make it record it, nor sort it out for playback. So I said screw it and put it away :confused:
pwtr02ss
Tennessee
You’ll get it sorted out. Don’t get discouraged. @randeez or @Dantheman1540 can we get a little help up in dis *****. My OG interface is completely different than the fancy new one
randeez
south florida
you are a failure, but we'll get thru this.
so where are you at with the credits? fpcm? did you buy a credit for all of them or trying to just do ecm and tcm?
for the logs everytime you stop a log it should auto save to ...... HP tuners > VCM Scanner > Logs. if you open the hptuners> logs and tunes folder then there will only be the sample one in there
after you stop the log if you want it somewhere else do a save as on it.
unless you are using the mpvi2 and running it with just the dongle plugged in and then transfering to computer - i dont know how it saves on the dongle . i still use a mpvi1
Thanks, Tyler.
I am... I am. I dishonor my famary.
Now that I've vented with my previous post then distracted myself by going for a drive to pick up my kid and scoring a commercial-grade Kee edger from my rich neighbor's trash (looks great and has good compression, probably just needs cleaning), I'll move this over to my build thread.
Thanks for the support, homies.
Williammdzialak80
