Just Fishing
Can't fix stupid
Utah
What does this "barbell" do?
goes in the rear of the block and diverts oil down into the filter housing/pan
then when the return path, it routes up the back of the block to lube the engine.
Serves two purposes,
Prevents unfiltered oil from passing to the engine parts
and keeps oil from escaping from the rear of the block.
St. Louis
Guess this has to do with the block design and the way the oil passages run in the block.
Even though I've had my 2001 since 2006 and that 5.3l has 240k miles on it, I've never heard of this thing, but then again, I'm only really familiar with older 350 blocks and Ford 302/351 blocks.
Don’t feel bad. I never heard of it either until I had already installed my new trans for the second (or third) time and had replaced the rear main while it was accessible. Then of course I start hearing about replacing the barbell when you have the trans out. :mad: Mine has 170k and no issues. Fingers crossed. I never wanna do the trans again.
CaptainAmerica1
Arlington TX
Chasing pending P0171 and P0174 code. Service stabilitrac pops up when I stop at stop lights, immediately goes away as soon as I start moving again. At my Gf for the weekend so my Tech2 is at my apartment. My autocal shows 29% ltft maybe 6-8% stft… haven’t even popped the hood to look around yet… temps just dropped into the 50-60s lately so I’m hoping it’s a vacuum leak or something loose/dirty maf…
madmanjustice
Just Fishing
Can't fix stupid
Utah
I have two air ratchets like that plus my Milwaukee M12’s (1/4 & 3/8 speed ratchet). The one he was using in that video had the power of a standard 1/2” air impact minus the “nose”.
Here are the main ones i use.
I believe i have a few more, but put away since these ones are my go-to
That Aircat on the left does 130ft lbs!
It's a knuckle buster, I have had my hand pined by it a few times. :jester:
It's slow but has a ton of power.
Close to "impact" but it won't hammer.
you can do it manually, but it transfers all of that into the hand. :emotions33:
(I love aircat's stuff)
The one next to it is branded "acdelco".
it's a very nice ratchet, iirc i got it for about $20 on an amazon clearance.
I loved it so much i got a spare while they were cheap and available.
then the new one, next to that, astro 3/8 with a built-in socket swivel.
Used it for the first time today.
It's nice, but that ac delco has a longer nose and no external moving parts, so it will stay as my go-to.
I'm also dumping that swivel air fitting on the end, it's stupid.
Then the 1/4in
it looks identical to the astro version, and at the time it was about half the price.
Its good, i use it often.
But it does get a little hot with heavy use.
Just Fishing
Can't fix stupid
Utah
As you can see from the above image, i got the bearing cap pulled.
I caught this one much sooner.
the thrust bearing was out of spec but not totaled.
the wear in the bearing is also nicely polished.
I'm going with i need to loosen up the clearances a little.
And i'm on the fence if i want to try the crank once more or call it and yank the engine.
While working this, my new diamond d holster came in the mail for the 'ol 500.
So, i got to model that for my wife, currently doing a little breaking in of the leather...
Wife said what every man wants to hear: It's huuuge! :cool:
sipping some whiskey right now, trying to decide if i want to say fk it and yank the engine like i know i should.
Or give it one more go.
Nice thing, non "race" bearings are cheap.
$60 and i have mains and rod bearings...
more sipping to think about it.
:hmmm2:
Flounder 975
