gs_scott
- Joined
- Dec 24, 2021
- Posts
- 2
- Reaction score
- 2
Has anyone ran into this code? I have checked all of the ignition fuses. Unplugged all coils to confirm they give a code but no luck.
Thanks,
Thanks,
Thats Bank 2. CHeck the bank 2 fuse first. THen I'd check for voltage on the connectors of each coil connector on bank 2. You can get the wiring diagram with the Haynes manual, for which 2 wires you need to meter out.P135B is the code I am currently getting on my 2017 Traverse.
hello, my first time here .. i can't believe i found humans that are experiencing the same thing i am i hope you can help me .. my cyl 1 coil pack melted (my traverse has been misfiring for months i put spark plugs and a new coil pack it still miss fired here and there. anyway, the cyl 1 coil melted on me driving .i put a new ac delco coil pack and now i have a code IGNITION COIL SUPPLY VOLTAGE BANK 1.. do you know what that is ? and how can i fix this .. i really need help on this. from what i read that you all have some experience. i have 2012 traverse .Welcome to TYF. Consider introducing yourself in the Introduction forum, and perhaps put some vehicle info in your signature so we know what you drive.
Bank 1 is the driver's side of the engine, so remove and inspect all of the connections for the coils, not just on the coils themselves.
I know that the Traverses had a connector issue like this for a year or two; other informed people will probably chime in with suggestions.
