Super Moderator
Elev 5,280
Ok looks like I'm screwed. It IS leaking from the top of the fuel pump. :(
I don't see the wet on top in your pic; I'm just seeing the evap vent connection.
Time to run the tank down pretty low. When I did mine on my NBS I ran it until the low fuel light came on, then some more. I figure that I have about 5 or 6 gallons in it yet when the light comes on.
Sparksalot
Bastrop County, Texas
Do with it? Limped home 500 miles from Big Bend with a burst upper tank on the radiator. A 2.5" rupture near the top, so the engine still had coolant the whole time.
First I had to limp 25 miles out of the desert to try and patch it with JB Weld. Worked decently, but I couldn't reach the entire rupture, so it seeped all the way back.
Cold Case, I'm about to call...
Sparksalot
To go with that thought, what is the thing with the rubber gizmos on the oil and transmission cooler lines going into the radiator?
Dirty pair are thecopcar. Off road donchaknow. Clean ones are similar on theothertwin.
Mikegrz
