Denali subwoofer and amp install 2022
RST_FRED22
How much space is there under the 2nd row captains? Might just throw a powered sub under there while JL works on their stealth box.
I don’t take delivery for another 4 weeks or so so I can’t just go look.
Dude you ever go with the JL powered subs under the rear captains? If so how did it turn out!
mikew2069
There isn't enough space. I did buy a powered kicker 10" hideaway sub but haven't installed it yet. Plan is to just put it in the back and install it so that its a quick connect to remove it if I ever need the cargo area.
I'm not audio/electrical inclined so I need someone to post a detailed how-to on accessing the Bose amp. Until then, I've been working on wheels, chrome blackout, etc.
PoplarJay
Just curious as to if you made any progress on your install, have you looked into LJS customs loop back harness for your remote wire and signal wires, anyone have diagram on replacing all the oem speakers
when you add the sub you may have to unplug the anc mic's otherwise it will probably cause some feedback problems
JohnnyFamous
JohnnyFamous
Morning all, late posting this, but I completed this upgrade a few months back; all I can say is wow! The system came to life, and it is a night and day difference. I settled on an audio control amp ACM 1300 AMP and used the high-level input from the factory sub, and installed a JL bass wedge The local shops told me it might not have enough signal from the factory high level to work, but I reached out to audio control, and they were confident in their product. I was contemplating a JL amp with more power, but when I spoke to them, they weren't as confident and the audio control has a built-in Accubass. There is bass roll-off on the factory unit, so the louder you turn up the volume the lower the bass gets. If you planning this with a different amp with more power or more subs, I would suggest you use the audio control LC2i to increase the line output but, more importantly, give you acubass. LC2i
I was surprised by how little information there was and how the local shops were not willing to touch it.
I got a deal on the 10 Jl wedge, which I don't believe they make anymore, JL knows their stuff and I highly recommend going with a pre-made JL product. The hardest part was running the 8 gauge power line through the firewall; take caution there but not impossible. There is more than enough bass here to hit hard or play clean; up to you! If you are looking for sound quality, this integrates very well and can be adjusted to pound hard and shake. You could go with more power and a single or twin 12 if you were a bass *****, but the sound quality is matched with this 10 in the cab, don't let the low power amp fool you; these are full RMS and professional quality - any more is just for the people looking at you across the street, it depends on how much you want to show off if I was 20 I might go with 12s and 1000 watts.
As far as the rest of the bose system, and I hate to say it as I am not a BOSE fan, it sounds amazing. There are NO other upgrades required, nor should they be considered IMHO. I don't think you could improve on this system unless you spent 10-15k on ultra high-end separates.
Fast_AT4
RWM +1
SW Florida
View attachment 377140View attachment 377141View attachment 377139View attachment 377143
Much thanks.
Where is your remote wire?
bobbywdatool
