I am new to Chevy transfer case swap so be kind
DumbCluck
Transfer Case Swap I have a 2002 Suburban and changed it out with a Tahoe Transfer case I think don't know what year but the wire that operates the engagement does not fit the Suburban connection, I heard their was a adapter or a harness to make it operate can some one school me on this subject, and yes both was mp262 and same ratio, thanks in advance for any help I might get
Do you know the year of the Tahoe? How about a photo of the plate on the transfer case?
Miami-Dade
Super Moderator
Welcome from Miami!
You came to the correct forum for your questions.
rockola1971
Indiana (formerly IL)
Sounds like you mixed generations of vehicles.
Welcome to the Forum from NH.
Pics of the truck, please.
One thing that you do not have to worry about with this Forum is being ridiculed. Does not happen here, unless in jest. A**holes get booted out of here pretty quick.
rockola1971
I can try to get the year model of the Tahoe but no having much luck
Get us a pic of the transfer case circle plate and it will verify transfer case model and it will also tell us the year model of the donor vehicle too. Pics of the plate of the donor vehicle and the plate on the Tcase thas was in your vehicle originally. Also your RPO code that starts with a NP will tell us what is supposed to be in your vehicle from the factory.
Super Moderator
Elev 5,280
NP262, New Process Gear.
If the Tahoe still has its glovebox, get the "N" RPO codes off the sticker.
Not sure that model exists:
Ja1034
