1998 yukon Mystery p0300 and rough idle still
exp500
Did you scan it when plugged? Generally if no fuel trim or other changes noted, then lower gaskets a definate leak. Should take you about 4.5 hours depending.
O
OilBurner2003
I did not scan it, and yeah, I’m a little nervous about taking it all apart. Damn things so old I’m worried I’ll snap a ground trying to take the wires off.
east302
Mississippi
Yeah, I’m having a complete brain fart - must be that time of day.
Never done the test but was trying to visualize the whole process of air being drawn out of the lifter valley through the intake and what you’d see at the dipstick. Would you just as easily see vacuum at an open PCV hole (or open oil cap) if the dipstick were plugged and the intake is leaking?
Been a long day, probably should quit typing, lol.
O
OilBurner2003
Haha no worries dude, I’m gonna start on the intake tomorrow! Whether I finish it within a week no one knows, I’m gonna do some research and I’ll probably have questions for you fine gentleman if I get stuck with something.
exp500
Be very careful disconnecting Q/D heater hose at intake manifold. Cast zinc very weak/corrodes quickly/easily. if it breaks, use a small chisel about screwdriver size and bend remaining threaded portion towards center of hole. Eventually you will break a chunk out and can continue removing until either you can grab it with needlenose or like a 90 icepick to pop pieces out and clean threads. Good Luck!
Replacement part about $15.
O
OilBurner2003
I will do my absolute best to not break it!
O
OilBurner2003
Hey, I think I found something really important. Something didn't show up on the smoke test. This is what looks like some kind of vacuum booster? While I was getting ready to rip off the intake, removed the air box and I saw this. As soon as I touched it it fell off. I got to thinking and was wondering if it was a vacuum line, started the engine and put my thumb on the end of the line, sure enough it's a vacuum of some sort. I'm not even sure what this is, but the other end of it runs into the firewall, kind of hard to see back there. So before I do this 6 hour job...What are your guy's opinion on this? Both sides of the line are cracked and basically crumbling apart. Not even sure if it's related, But we had a long talk about unmetered air and vacuum lol.
east302
Mississippi
Your picture shows the heater water valve. The vacuum line goes to a solenoid on the firewall which has another vacuum line (hard plastic) that goes across the intake to the PCV valve fitting.
When the “MAX” detent is selected on the a/c temperature dial, the solenoid is energized and vacuum is applied to the water valve. That closes the valve, shutting off coolant to the heater core and maximizing a/c performance.
Yes, it needs to be either fixed or just cap the line at the PCV fitting.
O
OilBurner2003
Roger, thank you. I couldn’t find that information anywhere! Back to intake disassembly!
raptormc
