Random driveline clunk when accelerating from a full stop
mikez71
Just did driver's side, not toooo bad.
Kinda easy, kinda worried, tired and scraped up feeling after I was done.
jack up truck / put on stands
remove wheel (6 nuts)
remove inner fender liner (4? 7mm screws and maybe 8? or so push pins) a few electrical plugs (push them up with a pliers)
crank steering wheel one way (so you can't possibly clock anything wrong) and remove steering coupler (2 bolts)
destroy mount heatshield so you can see the bolts to block
jack up engine on that side
Now you need the right short extensions/wobbles/angle ratchets whatever to loosen the 7 bolts.
and wiggle the mount out of there!
The H3 mount does have a sleeker heatshield which may make installation a tiny bit easier.
Passenger side looks like starter needs to come out...
mikez71
I tried without disconnecting steering, but could not wiggle the mount out of there!
Now on the pass side..starter out, heatshields off, bolts out (that front lower one was fun, swivel head 72 tooth was useful) and mount is loose!
BUT looking like exhaust manifold has to come out.. unless I loosen the driver side mount and try to lift the engine more..
solli5pack
I did both of mine two week ago. D/S wasn't bad but P/S was p.i.t.a. Lots if YouTube videos showing many different angles of attack. If the exhaust manifold was removed both side would be a cake walk but that's no easy feat on old truck. I would say the below swivel attachments are mandatory to get to the bolts. I also utilized impact tools and used the job as a reason to finally buy a battery powered impact wrench. I paid the dealer $1100 to do the d/s on my Suburban 4 years ago.1000003780.jpg
89Suburban
Bull in the china shop
SE PA
I did both of mine two week ago. D/S wasn't bad but P/S was p.i.t.a. Lots if YouTube videos showing many different angles of attack. If the exhaust manifold was removed both side would be a cake walk but that's no easy feat on old truck. I would say the below swivel attachments are mandatory to get to the bolts. I also utilized impact tools and used the job as a reason to finally buy a battery powered impact wrench. I paid the dealer $1100 to do the d/s on my Suburban 4 years ago.View attachment 424899
Yeah man! I just got one of those a month ago I LOVE IT!
j91z28d1
the hummer ones don't need a heat shield?
I can see how that would make it a bit eaiser to get in. one video I watched the guy had to take the pass side mount itself apart from a bracket to get it in.
not that it matters for you guys, but I have to laugh about having a giant 300v inverter sitting above my passenger side hiding everything lol. but I don't have a stater to remove haha. fml
mikez71
Hummer heatshield is smaller, inside of bolts instead of enclosing the engine bolts.
I wonder if 4WD has anything to do with getting it out without removing the steering shaft.
@donjetman Did your driver mount come out the side above the frame rail?
GMCasual
