New Exhaust Manifold Advice
latvius
Ariton Alabama
I have a 2005 Denali Yukon and am going to have the broken exhaust bolts replaced and want to replace the original manifolds. I want to keep the existing stock exhaust so I need them to bolt up like factory. I was told someone sells some SS "header" type manifolds that would bolt up. Replies appreciated.
* I already bought the ARP bolts*
Unless you are doing some major engine mods, your stock exhaust manifold is more than sufficient for your motor. Any shorty headers won't improve performance.
The best improvement that you can make, assuming that you are going to remove the broken bolts is to replace them with ARP brand bolts. This way, you won't have to replace them again.
latvius
latvius
Ariton Alabama
Might be better to show, than tell here - pics?
That said, unless your engine spends most of its time OVER 4000RpM, negligible additional power (stopwatch might not care) from 'shorty' headers.
You cut off the part where I said "I was told" so I don't have any pictures.
terryseverson
