Best Magnetic Ride Replacement for Motion Sickness Prone Family
K2xxSteve
Maryland
Hi everybody, first post. Glad I found this forum with a suspension specific sub. Makes it so much easier to research and read up.
2018 Suburban Premier 4WD owner here at 96K miles with (drumroll) you guessed it Magneride shocks needing replacement. I know there's about a zillion threads on this in here already, but I'm looking for some very specific feedback due to a few motion sickness prone family members. I'd like to not spend $3-4k if I don't have to, but can't afford to screw this up either.
I'm wondering if there's an aftermarket suspension option that's maybe 75% as firm with about 75% the body control as the OEM magnetic ride shocks and springs, but going to a passive conversion and without all of the expense? Have been looking at MAGDELETE with Bilstein 4600 or 5100, Arnott, and others.
For perspective, we've loved the OEM Magnetic Ride suspension. Amazing control, almost no body roll in corners, and no nose diving on hard braking, etc. Zero complaints from the motion sickness prone family members all these years, but man is it firm. And especially unladen just on the work commute, the ride is really harsh and unrefined also. We don't need it to be quite this firm.
I test drove an LT with Premium Ride suspension before buying, and that was the opposite extreme feeling way to boaty and soft. I'm not motion sickness prone, but even I was starting to feel a little motion sick on the test drive, so that was a no go and we got the Premier with the Magnetic Ride.
So I'm trying to understand what some good options might be going the magnetic ride delete route, but unlike the OEM premium ride option, would still land on the firm side. I'm looking for something that's still firm, but not harsh like the magnetic ride has been. A little body roll is okay as long as it's well controlled, but cannot be wallowy. I'm guessing I need to stick with a digressive valved shock? Not interested in changing ride height, but understand some of these kits might result in a slight lift on the front end, which I guess is fine.
Additional notes: No towing with this vehicle, but it does have the max tow package and would like to keep the rear air-leveling suspension active also, as I occasionally load it up with heavy cargo.
Thanks for any feedback and help! (still reading and learning a ton here)
the ride with bilsteins is decent, you would need to either buy the shock and have it installed in the oem front strut (spring compressor) or just buy a whole strut
the rear will need a slightly stiffer spring with the bilstein
then of course resistors
if you put a leveling kit on the front then you could increase the tire size and that may help also cushion the ride
other things you can add are Hellwig front and rear sway bars, that will help a little with overall control/sway when turning, cornering or having to make a quick lane change, etc
i make everyone car sick just from the way I drive
Welcome to the Forum from NH.
Pics of the truck, please.
If you have 22" wheels on the truck, many members here have found this wheel/tire combination to be significantly harsher than the 20" wheel option. If you do have 22" wheels, this may be a better option to achieve what you desire.
frank1
Drag a short piece of chain, from frame to touching the road with a couple of links draging.
K2xxSteve
K2xxSteve
Maryland
Thanks! It does have the 22's. I had actually intended to buy an identical truck but with the 20's, but it was sold the day before so picked up this one with the chrome dubs. It was a closeout 2018 as the 2019's were starting to hit the lots. It actually handles amazing. Fun to surprise the crap out of BMW and Honda drivers in corners, but the tire prices are ridiculous also, in addition to the lousy ride unladen. Not a bad idea to convert back to 20's, especially since my tires are nearing end of life anyways. Good thing to consider for sure.
K2xxSteve
K2xxSteve
Maryland
Thanks for the suggestions. Did not realize FSB/RSB were available for these trucks, so good to know.
gtrslngrchris
The Fox 2.0 coilovers in the front seem to be the plush option from my limited experience and reading others. I opted for air-only rear AC Delco shocks and have been pleased with front and rear so far. I think in general the sway bar upgrade makes the truck feel much tighter without actually making the ride worse but it does make anything you roll over on one side but not the other feel more harsh (think rough road or pot holes) but the ride overall should still be softer than magride.
If you drive predominantly on pavement, I suggest that you consider Michelin Defender tires. They are pricey, but they are warrantied for 70,000 miles, and they have taken everything that the NH winters can throw at them.
Also as stated above, the Hellwig sway bars are incredible, and would deliver an improved handling experience well over what you have now.
K2xxSteve
K2xxSteve
Maryland
I figured I would write in to MagDelete and ask them directly about what I basically posted in here, which option would have about 75% the stiffness and body roll control as the OEM Magneride. Their response was perplexing to say the least. Is this not completely opposite? The OEM Magneride shocks and springs are much more FIRM than the "premium ride" passive suspension, and the whole point of Magneride is to REDUCE body roll and pitching while having some dynamic adaptability on the shocks. I've always been amazed at how flat the cornering is with this 6000lb SUV, and how little (zero) nose dive there is even in panic stops. It's a night and day difference vs the standard premium ride. What on earth is this guy talking about? The Magneride suspension is super soft and has tons of body roll???? What?
Anyways, totally not helpful and now I'm even more confused. Does not instill confidence in purchasing one of these kits to say the least, even though I've seen some positive reports on them.
JayySalas
