2025 Tahoe 24" Aftermarket Wheels
tightchevelle69
Florida
Bought a 2025 Tahoe RST with 22" wheels. Looking to upgrade to 24" Wheels. The factory 24's come in a 9.5" width, the aftermarket ones come in 10". What backspacing and offset should I be looking for? The ones im looking at are 24x10 with 6.44 backspacing and +24 offset. Pic of truck and pic of the wheels im looking at attached.
Dag300c
Just got a 2025 tahoe high country im going 26x10 and ive had people recomend +15 for flush fitment and others recomend +20 to stay in just a little bit inside fenders. I dnt know what to go with but i see alot of people prefer flush fitment over inside the fenders. I Got from here till spring so i can make up my mind. Let me know if you end up getting anything
tightchevelle69
tightchevelle69
Florida
I did order some 24's with all terrain tires. They were supposed to be delivered tomorrow but still havent shipped. Hopefully they will be here in the next week or so and I can shoot you a couple pictures with the specs of the wheels. I also ordered lowering links (ours has the adaptive air suspension) to drop it down 1-2".
KMeloney
You already ordered the wheels but don't want to tell Dag the specs? That's curious... Just want to make sure that they fit first?
I hope you post pics here. Looking forward to seeing them!
tightchevelle69
tightchevelle69
Florida
I can post the specs but without pictures to go along with it I dont think it would really help.
Wheels:
Brand: Factory Reproductions
Model: FR98
Model Other: Escalade 12 Spoke Replica Wheels
Part Number: 98410316502
Wheel Finish: Gloss Black
Backspacing: 6.72
Bolt Pattern: 6x5.5
Offset: 31mm
Wheel Diameter: 24
Wheel Width: 10
Hub Bore: 78.10
Load Rating: 2200
Wheel Exposed Lugs: Yes
Wheel Material: Alloy
Wheel Structure: One Piece
Wheel Spoke Number: 6
Tires:
Brand: Venom Power
Model: Terra Hunter X/T
Inventory Number: CVPXT04
Aspect Ratio: 40
Inflated Diameter: 32.98
Inflated Width: 11.22
Load Index: 112
Section Width: 285
Service Description: 112H
Sidewall: Black Side Wall
Speed Index: H
Temperature: B
Tire Rim Diameter: 24
Tire Type: Hybrid AT/MT
Tire Type2: All Terrain
Traction: A
Tread Wear: 500
UTQG: 500AB
Weight: 44.16 lbs
nomech
Senior Member
@KMeloney @Dag300c I finally got the wheels and tires installed a couple weeks ago but this was the first time ive been back on the forum.View attachment 447314View attachment 447315View attachment 447316View attachment 447317
That drop looks great along with those rims.
The color looks to be dark ash, I can't decide between dark ash or black. I like dark gray colored vehicles, but it also looks like dark ash has a dark purple color based on the way the sun hits the paint.
tightchevelle69
tightchevelle69
Florida
It is dark ash metallic. It does sometimes have a purple/blue hue depending on lighting but it does look black at night. It is a really nice color and IMO the metallic helps hide some dirt and microscratches compared to the standard black.
nomech
Senior Member
Does your RST have air suspension?
What did you use to lower the vehicle?
Any tire rub with the wheel/tire combo you have?
I put factory size tires on my factory wheels and I have a little tire rub if I turn the wheel hard one way or another and I typically only do that if I'm in a tight spot and usually I'm going very slow (on the brakes, most of the time). I posted on here and people said that the tires I bought just have a bit more rubber than the factory brand. Anyway, I was just curious about your setup since you have wider wheels, but the offset also plays a factor into that, as well.
Flounder 975
