Tonyrodz's Tahoe Build Thread
Are you making the correct flare for the application?
I haven’t. Not sure if I should try yet.
Like @Fless has said, there are different types of flares and you need the correct bits for them.
Have any idea where I could find what specific flare I'd need--or what style it is? Might try to go to HF for the correct tool. The one i have only makes 1 style of flare.
As far as what your truck needs, I am unsure. Have you tried Inline Tube for info and availability? Your old original line should match up to one of these pics.
Unfortunately I don't have the old line to compare. I had someone else do it. Thanks for the pics. I'm gonna save those.
I've never heard of Inline Tube. They sell hard line already flared? I still have a roll of brake line i can use, also some compression fittings. I found out the hard way that threads on the fittings aren't all the same.
GMT800 SUV/Trucks
Military
I believe, yes, they pre make them and flare them. Look it all up at their site or call them.
When I did the stainless steel transmission cooling lines on my girl's 1990 GMT400, they were pre bent and flared. They also advertise brake lines/hoses.
89Suburban
Bull in the china shop
SE PA
Hang in there brother. :console:
Geotrash
Dave
Richmond, VA
Wow! What a cool source for brake and fuel lines! Had no idea they were out there. Thanks!
I still haven't had time to look any further into the brake situation. What else would cause a soft pedal that goes almost to the floor?
Excelelecrtric
