- Joined
- Aug 2, 2018
- Posts
- 7,978
- Reaction score
- 11,035
If the dash light comes on, a trouble code is generated. If you don't see it with your scanner, my guess is that you are not using a quality bi-directional scanner, capable of identifying and displaying underlying control module or deep trouble codes.
I recommend that you get yourself a quality bi-directional scanner to add to your tool box. Then, you will be able to read ALL codes, along with a brief explanation/pointer to the source of your issue. You will literally save thousands of dollars in diagnostic and repair costs over the life of your truck, and you will most likely recoup the cost of the scanner within 1 year.
