Avoid GM Parts Giant if at all Possible
Marky Dissod
Sign of the times pretty much.
Purchased a set of aftermarket headlamps for my wife’s car.
Within a year, the protective coating on the lens began to peel like a bad sunburn. It affected the clarity.
It was only days after the warranty expired. The company knew they had a production problem.
After experiencing a similar issue as you had experienced, I simply ordered another set of identical headlamps.
I swapped them out and returned them a few months later for a full refund.
Apparently everybody’s happy because the ppwk & warranty issues were all directed to the manufacturer vs the seller.
Times change, contractual terms do not.
It’s almost like I purchased an item I knew was going to fail and implemented the warranty process prior to it expiring.
It’s funny that I’m actually protecting the seller from his predatory distributor.
Is my soul safe?
'Yes' or 'no' is woefully inadequate.
Your soul is safer than the person who sells items using the business case described by @PPV_2018 in the previous post.
SirReal63
Bertram, TX
I had my fun with GMPG, I was going to order an ignition control module for a SBC, a part that weighs .4lb and is 2"x3" and they wanted to charge me $30 for shipping. The ICM cost $35 so I questioned them and the only answer I was given was they cannot amend whatever shipping cost comes up in the computer. I did not buy it from them.
A previous order for an oil pressure sending unit for the C4 showed in stock but after a week of no shipping they cancelled the order. I don't believe I will order parts from them again.
I've had similar happen with the Lucky Brand Jeans website. After trying for a couple of weeks and getting nowhere, I filed a complaint with the BBB, including screenshots of what I ordered and photos of what I received. I received a refund and an apology the next day.
But why should it even get that far....these companies forget who keep them in business.
RVTSP21K
I wish I remembered this thread. I ordered a new fuel tank through GMPD for my wife's 2011 Z71. It's supposed to come tomorrow. Fingers crossed.
Tssonebay
