lifter info
J
j91z28d1
J
j91z28d1
I just suck up the price pain and use Morel.
which ones did you buy? I see 1300$ lifters?
J
j91z28d1
I've had zero issues on the lS engines I've built, using the Delphi LS7 lifters. Identified by the gold color retaining clip in the end.
An often overlooked part of an engine rebuild are the lifter bores. Just as important, if not more so, than the cylinder bores. Issues are more common with the aluminum blocks at greater than 200,000 miles. Like everything else, it comes down to regular oil changes with a full synthetic oil using quality filters. Well they are repairable with a sleeve, the economics of repairing it depends on how many lifter bores need to be addressed.
do you remember where you bought them at? the original ls7 lifters installed in ls7 would seem to be what we really need. I've driven a buddy's ls7 c6 and it ran right up to 7k rpm and smacked the relimtied with zero sign of drop off. they did something right for a hydraulic lifter to do that on a stock push rod v8.
Charlie207
LFOD, New Hampshire
curious if you noticed if they had the gold keeper clips?
I have noticed looking around, the pics of most listing's will show every angle but the gold clip.
Sorry, I don't remember the clip color. I searched through my photos, and don't have any of the clip either.
Pressureangle
I actually used their least expensive ones, after some long discussion. Still higher quality than next best. They manufacture a lot of the super-high end race lifters under private label.
bmxbry9
