Valvoline Restore & Protect experiment
Super Moderator
Elev 5,280
E85 is a scam. MPG drops 25% and it costs the same per gallon, if not more.
Not a scam, but a tradeoff and personal decision if your ride can use it. Lose a few mpgs for typically less cost/gal and higher octane. If there's not a significant difference between premium price and E85, then it's probably not a good deal. But it still has its place where it makes sense.
j91z28d1
yes, ethanol/alcohol fuels are corrosive and absorb water. which is a good reason it really shouldn't be in our normal gas. e10/15 in older cars and small engines. plus cause you store over the winter is a hassle.
but e85 in the correct application is amazing. Comparable gasoline would be $10 a gallon or more
donjetman
if you've got the old style valve cover, you need to update that since it's the cause of most of the oil use. cleaning rings can't solve a hardware problem. but I'm looking forward to your results.
You nailed it with the valve cover causing the problem (oil consumption) see TSB: https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
@the blur
did you change the driver side valve cover to the new improved design?????
as I said previously, the quik fix is to also do a combustion chamber/piston soak.
Valvoline R&P says it takes 4 normal oil change intervals to cleanup piston deposits. IIRC they don't say anything about unsticking piston rings.
Valvoline does sale a oil specifically designed to clean piston rings - Valvoline Premium Blue "Restore" 10w30, available "only" at Cummins dealers for $80/gal, pt# CA877377GA.
I have used a mix of VPB"Restore" in 3 of my daily drivers. I am currently using a 33% mix of it in our 07 Denali L92 w/200k miles that doesn't consume any oil. I fixed that problem 6+ yrs & 70k miles ago by doing the TSB ds vc & combustion chamber/piston soak over a weekend. I'm using the VPB:Restore" to further cleanup the mess (carbonous deposits) in the engine left behind from the abuse of the previous owner & GMs poor original valve cover design.
https://www.tahoeyukonforum.com/threads/valley-cover-crank-pulley-etc.149036/
and
https://www.tahoeyukonforum.com/threads/sparkies-no-beno.108579/
Marky Dissod
In NYC, 87 octane is $2.89 - $3.19 a gallon, depending on the gas station.
This calculator figures STRICTLY by Miles per Dollar:
Input the price of 87 octane in your area.
In my case it suggests that if E85 is priced over $2.26, I should use 87 octane.
Since E85 also has a mild detergent effect, I'm willing to go as high as $2.49 a gallon.
However, in the 5boros of NYC, E85 is priced too high, so it's 87 for me unless I'm in Long Island.
T
the blur
Cyber Space
I have the 2013. Comes with the revised valve cover from the factory.
Furthermore, why should I run E85 and get 25% less fuel mileage? It's not a race car, it's a daily driver work truck. Suburban LTZ. Horsepower is meaningless around town.
j91z28d1
have you used it to check milage? cause the 25% number sounds a bit official like something you read.
I could be wrong and you did the math thou.
the 18th letter
Northern New Jersey
Because in the long run, it leaves less carbon in the combustion chamber, and even cleans it out, albeit very slowly.
If you use your vehicle less than once a month, I would not use E85, but mine's a daily driver.
I don’t use it much during the colder months but May to September I try to run 2 or 3 tankfuls. Some say it might be more beneficial to run them back to back so I may give 2 a try and see.
Tinkerer4
