What is the quarts "range" on the dipstick on these trucks?
viven44
Dallas, TX
Smart man!
I got roasted when I asked the question about 8 qts not being enough. Granted things may have changed with the oil pan size, but a number of years ago, I think up to about 2015, all the V8 trucks indicated 8.5 qts with filter. Then with a single piece of paper, GM updated the oil fill with filter from 8.0 to 8.5 qts, nothing changed with the motors that had already been been built.
I checked my oil level when I purchased the truck and before the first oil change at 500 miles and matched the level on the dipstick. 8.0 qts did not even touch the stick when I initially poured the oil in. Sure I could have waited until overnight, but this was not my plan.
I run 9 qts and have ZERO issues. More oil to be diluted by fuel, more oil to get dirty, more oil to lubricate the engine. Given all the 6.2l problems are OIL related, this is not going to hurt anything. I also WILL NOT run 0W20 oil in the engine. Either 5W30 or 0W40. After tracking the oil temps on longer highway cruises, I am going to switch to 0W40 and see what happens with oil temps and the oil analysis.
The 6.2l in the Camero's spec 0W40 and the DI 5.3l and 6.2l in boats (doubt they have DFM in these) spec 5W30. 0W20 was speced because GM sold too many 6000 lb trucks and they were worried about the CAFE numbers.
If using 9qts puts you at or below the max level on the dipstick (of course when checking on level ground), I'd say you are good. If you are a lot higher than the dipstick max by using 9qts that would be concerning. We don't want the crank aerating the oil.
jfoj
Fine line between "lugging" or Low RPM/High Loading and High RPM/High Loading. High RPM full throttle runs just "wears" things out due to the sheer number of revoltions the engines makes as long as you do not stress things to the breaking point. Low RPM "lugging" just beats the engine down in a much shorter period of time and loads things like bearings probably beyond their limits.
The issue to get these 6000 bricks to obtain 18 MPG or more on the highway, the large engine cannot be spinning too many RPM. So the TCU (Transmission Control Unit) really manages Torque. The 6.2l puts out a lot of Torque at lower RPM so the transmission is programmed to use the Torque to keep the RPM's low. Behavior is different on the 5.3l as it does not have the raw Torque the 6.2l has, so it runs at higher RPM's to pull grades, downshifts a lot more. It may run at similar RPM on flat surfaces as the 6.2l, but find a small inclince and the 5.3l is spinning more RPM to keep up speed.
This lower RPM operation puts a lot of load on the engine, specificaly the rod bearings. With the oil temp these engines run on the highway at 225F+, and I only have a good 1st set of data for like 64F ambient temps, not the crazy Summer temps of the high 90's-100's and the pavement being like 130F from cooking in the sun all day, 0w20 starts to look and operate more like 0W10 and under extreme conditions the oil is more like 0 weight overall. Not ideal.
It is not the engines are not getting enough oil, it could be, but what oil the bearings are getting is just too thin to hold up under the extreme loading and keep the engine bearings properly lubricated and componets cool enough. Oil also has a job at cooling the engine, once the oil gets too hot, it cannot perform its intended lubrication purpose and the oil viscosity will need to be adjusted for the operation requirements of the engine at higher oil temps.
While thinner oil has lower pump loss and lower "frictional loss" or drag on moving parts rotating on the bearing surfaces, you can gain Horsepower using a lower viscosity oil. There is balancing point to keep the oil cool enough so it does not thin out more than expected and under severe duty thinner oil may not provide enough engine protection with a sufficient oil wedge in the bearing area once the oil temp increases and the oil thins out. UNFORTUATELY GM recommends 0W20 for towing as well! No way in hell I would run 0W20 with the oil temps I see when the truck is loaded with nothing but a full tank of fuel and my smiling face.
Pretty much all of these 6.2l failures lately are bearing problems, and usually bearing problems are due to lubrication problems and overheating due to insuficient cooling. And for all the 20,000+ 6.2l failures, these are highly unlikely any sort of manufacturig problem or defective part at this point in their lifespan. Many environmental factors, useage factors, maintenance factors and the common element to almost all the engine failures is 0W20 oil.
jfoj
9 qts may be slightly above the full hash mark, but there is plenty of room below the windage tray and I have checked for foaming or aeration and seen nothing. Keep in mind, just check the engine oil immediately after shutting down the engine and see where the oil is shown on the dipstick, oil not fully drained back from the top end of the engine block.
Based on a number of folks indicating the full measure is around 8.7 quarts, we are talking about less than 10 oz extra oil in an area the footprint of the oil pan. You are looking at probalbly less than 1/4" overall.
Vladimir2306
Dump the 0W20 and move up to 5W30 or 0W40. The same 6.2 in the Camero is spec'ed for 0W40. And trust me the Camero does not weight 6000 lbs and run below 1700 RPM on the highway!
This is not the first time I write here. Our engines cannot have 5-30 and 0-40. The engine is designed for 0-20 for the entire service life of the car. The oil pump is designed for this oil, giving it a thicker one, and the pump gives pressure designed for 0-20, you violate the lubrication regulations of the parts laid down by the manufacturer.
Vladimir2306
Smart man!
How did you conclude that all the problems of the 6.2 are related to the oil? There are no investigation results yet. At the same time, the 0-20 oil was also on the K2 generation, on which people drove hundreds of thousands of miles around the world.
jfoj
Just do your research, the same oil pump is used on the 6.2l in the Camero and depending on what documentation you find and read for the Camero the recommened engine oil is either 5W30 or 0w40.
The Camero LT1 engine is pretty much the same as the L87 with the exception of a few different parts and tuning for higher output.
Vladimir2306
We've already discussed it, Camaro is a sports car. It drives at high revs, its job is to accelerate quickly. Tahoe/Yukon drives slowly, it drives mostly at low revs. The oil pump, even if it is the same, has different programming of the pressure it creates. At high revs, you need thicker oil, the lower the operating revs, the thinner the oil needs to be. That's why we have 0-20, and on Camaro it's 0-40.
jfoj
The majority of bearing falures almost always end up being oil related. Dirt in the oil usually made up of soot and/or sludge and hard carbon or contaminated oil that is broken down and has a loss of viscosity, most commonly fuel in these DI engines. Oil starvation is also a possibility, but this is not a common denominator I am seeing with the current 6.2l engine failures.
The K2 generation was not without its problems, but it was also a slightly different beast when it comes to both the engine and the platform. I big difference is the radiator shutters in the newer generation of these trucks for again MPG on the highway, to make a brick more areodynamic. Not entirely sure how much closing the shutters elevates the engine oil temperature, but it cannot help it.
I have not really put this out here yet, but I am really starting to think the DFM system is also another major contributing factor to the current generation of L87 failures.
With the AFM system you pretty much drop either 2 or 4 cylinders at a time. Pretty much a "symetrical" situation where you would never have fewer than 4 cylinders rotating the engine mass and propelling the vehicle. So the entire engine load is spread across no fewer than 4 rod bearings.
With the DFM system you can end up with an asymetrical operation of a single cylinder rotating the engine mass and propelling the vehicle. Then add to this the fact that the cylinder deactivation is constantly jumping around in different sequences. It is not likely the same 1 cylinder is always being called upon.
With the DFM system you have a crazy hodge podge of possibly 0 to 8 cylinders driving/rotating the engine. Assume, but have not confirmed that possibly during Decel With Fuel Cutoff (DFCO) the DFM engine may possibly deactivate all 8 cylinders for a period of time. But any other time, the system is jumping around and possible rotating the engine mass with as few as 1 cylinder. Think about the rod bearing loading when a single cylinder is trying to turn the engine rotating mass, compressing air in the deactivated cylinders, turning the torque converter and transmission and trying to somewhat propel the vehicle. Think about the forward and backward loading on the crank thrust bearing when all the crazy cylinder deactivation is going on. I beleive there are like 27 different cylinder deactivation combinations/routines for the DFM system vs probably 2 general combinations for the AFM system, might be more when you factor load into the equation, but in general is it pretty much a 4-6-8 cyliinder configuration not far from the early Cadillac V8 from the early 1980's.
While operating on as few as 1 cylinder may be great in philosophy, not sure it is wise in practice. I think we are all seeing down side of all the effort to squeeze a few more MPG out of a 6000 brick.
Too many parts, too many instructions, too many variables that cannot be controlled outside of the lab/developement area, too many things to go wrong.
jfoj
We would be far better off with higher Revs on this plaform, the 5.3l does seem to have higher Revs overall because it lacks the Torque of the 6.2l and needs to keep up speed by the TCM downshifting more gears. Also 0W20 is not 0W20 once you add gasoline to it and warm it above 212F/100C. It quickly becomes 0 weight oil or less! The only reason the trucks and many of the other models are running 0W20 oil is for the CAFE fuel economy ratings. Point of reference, in 2022 GM sold about 25,000 Cameros and almost 900,000 light trucks! The 6000 bricks are killing the CAFE numbers, so they need to focus on how to squeeze very 1/10 of a MPG of fuel economy out of the high volume sellers to help balance the CAFE average.
The oil pump for the LT1 and L87 use the same spring in it for the variable displacement function. As for the 2nd stage ECM controlled oil pressure "boost", I would bet the LT1 and the L87 are pretty much programmed very similiar, which is actually unfortunate for the L87 as the 2nd stage oil pressure "boost" should be programmed for engine LOAD and RPM, not just RPM.
Add the EXTREME rod beariing loading with a light weight compromised oil with constand engine loading near 100% at RPMs typically below 2000 RPM when encountering even the slightest grade, nothing good will come from all of this.
Look NASCAR engines typically run very thin oils, probably 0W20 or possibly a non multiweight oil of around 20 weight. They run are built for high Revs and to accelerate quickly. But NASCAR and other racing engines often run lower viscosity oil for a few reasons, mainly due to reduced oil drag in the bearing journals which equates to more net power or less parasitic load and loss of engine power.
BUT, understand a few things, race cars operate in a very controlled enviroment and the engines are purpose built and do not need to last more than 500 miles. They have larger dry sump oiling systems and very good oil cooling. They also sometimes pre-heat the oil before hitting the track and the warm up laps are both to warm up the tires and the engine oil before starting to race at 8000+ RPM.
Look at the track suggested oil GM recommends, they recommend things like 15W50 or even seem to feel the 0W40 is also adequate on some platforms. The higher viscosity oil that is recommended for track purposes is because the oil cooling is not adequate, there is a balance between daily driving and racing, and if the vehicles were build with large enough oil capacity and cooling for racing this would be a problem for daily driving.
I will have more data in the next few months at the Summer temps hit close to 100F and the road surface temps are 130F+ and while driving for 2-6 hours and I am guessing the oil temps are not going to be ideal for 0W20 engine oil to protect the High Torque/Low RPM operation of the 6.2l is these trucks. I will not have data for towing as I have no plans for towing at this point.
Vladimir2306
You use a lot of phrases like "Probably", "Possibly". You build hypotheses based on the wrong facts. Yes, the oil is getting thinner, well, the Manufacturer knows this and took it into account.
I'll tell you about summer and heat, the oil temperature in summer is about 120-130C, or 250-260F, so what? All oils work that way, the 0-20 oil that I pour in has a flash point of 220C. For it, working in the 6.2 range is normal.
Look, the 2025 models have been running for about 5-6 months. They have already driven more than 100-1000 miles, at which the 21-24 models broke down. There is no wave of failures on them. The oil is the same 0-20. DFM also works. AFM/DFM works for everyone on 900, K2 and T1 without problems.
It is very strange for me how one can take responsibility, advising oil different from the manual. We also have advisers in our Forums who advise pouring thicker, without having any engine calculation parameters. And who will answer then? You? Hardly.
I am sure that the result of the investigation will be just some nonsense, so as not to get into huge lawsuits, but in fact, GM has already fixed everything in the 2025 models. They just don’t advertise it. Like, for example, with the valve covers, where on models up to 2023 there was a 1 cm sealant leak, which resulted in increased oil consumption, and since 2023 the valve covers have become without this leak.
Venator
