Aftermarket fuel pump failure?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@exp500 excellent suggestion!
Looked up P0230 in FSM. It's basically what I thought it would be, the control circuit for the relay (not power side). If the relay fails the PCM would notice no current flowing through the circuit and trip the code.
I completely tore down this pump. WOW is it a piece of art. VERY well built. Took the armature out of the pump motor. Trying to assess the windings. Find something odd but not sure if it's an issue. Most of the windings are 0.6 Ohms but a couple are just over 1 Ohm.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
This maybe the fault. First anomaly I found. The commutator is very soft which is obviously for design reasons. However, depending on where I touch the commutators and or how hard I press resistance changes by as much as 300%
I don't think that's a design feature? Least I couldn't see why it would be unless (1) it's a fail safe although higher resistance is higher heat, which I presume is bad in fuel tank. Or (2) it's a way to slowly fail the pump as brushes wear, pump pressure decreases signaling time to replace pump. Otherwise my DC motor research showed this as being a condition of loose windings where the commutator connects to the winding / inductor wires.
I fiddled with another DC motor I have apart and it didn't behave that way at all when testing commentator and windings.
To credit of pump when I installed brushes (they are spring loaded of course) the commutator resistance was consistent across the motor leads (behaved as expected).
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Don't think it was the fuel pump. Installed new pump and get same pressure reading 52 PSI KOEO.
Pressure regulator squeals?
UPDATE the squeal is a function of the regulator. Maybe a sign it's going out? I swapped another regulator in I had in my garage. No more squealing. FYI ~ Cannot return defects to RockAuto like I can to my local parts store. I can only exchange if passed refund period.
The pressure regulator also makes a odd squeal if I jumper the pump on with engine off. I have two other pressure regulators. I may swap one of the others in to see if the squeal goes away.
Anybody had troubles with Standard Motor Products? The pressure regulator in the vehicle is one of theirs...
I will likely return it / swap it as it's loosing pressure.
Pump harness was loose: Removing the old pump I noticed the pump harness wasn't locked on... It slid off which may have been the problem.
Few other observations, the aftermarket pump draws 11 AMPS at 12.4 Volts (AGM battery).
Circuit is pulling 11 amps at 12.4V continuous relay rated for 10A @ 12.0V?
The relay is a factory Omrom 8567. In open air (hood open engine cool) the relay heats up on it's own to over 120F within a minute or two. I'm reading the data sheet for those relays. It's a little cryptic but appears the lowest rating for continuous current is 10 Amps. The pump maybe pushing the relay a bit much!
Datasheet: https://omronfs.omron.com/en_US/ecb/products/pdf/en-g8v.pdf
Going to buy a 30 Amp Micro 280 (mini relay)... I think I'll leave an omron in the port though to see if I can provoke the failure again then switch the relay with the 30 AMP one.
Junction block losses: I had suspected the junction block wouldn't handle the load. However, it seems to be a non issue... On input side it's dropping 0.3V that's all the way to the load side on the relay.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It broke down again :(
It seems as though the power line to the fuel pump is cooking the inside connection on the fuse block. I think I have to break the threaded part of the junction block to separate it and verify?
However, when pulling the relay the block smells burn. I let it cool down and truck worked fine after that.
I'm kind of wanting to just bypass the junction block and do an external relay and fuse now for the fuel pump. However, I am not sure which connector is B7 for the signal from PCM to relay?
If I was to put a larger connector inside the block... I'm not sure how to separate the fuse block without mucking up the flared end of the threads where the connectors screw in underneath....
Roilux
Burbank, CA
Spent an hour idling truck in garage to try and recreate failure. Not sure how accurate my fuel pressure gauge is... However seems when I put in my new regulator in I verified 57 PSI KOEO. I'm getting 52 KOEO right now.
There's also a weird noise in the fuel line when I hotwire the pump with my power probe. It's resonating through the whole fuel rail.
When I start the truck I don't hear that noise in the line set. It's like a squeaking noise. It's so loud you can hear it w/o the stethoscope.
Would you be able to hear that noise or pressure regulator squeal from the driver's seat? I had an intermittent noise I've not been able to identify. After the second occurrence the fuel pump was replaced the following day when fuel line pressure dropped to 40psi. (L59 engine)
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah I can hear it from inside (although it's not terribly loud). I honestly thought it was a slipping serpentine belt. Turns out it's most definitely a noise with the pressure regulator. I tried two regulators, both exhibit the same behavior.
Diving deeper it maybe linked to my engine's PID loops in the tune. The engine idles PERFECTLY with the spark controller. Then every so often it stumbles, runs every so slightly rough and the PCM picks back up again. I think that's when the regulator makes it's little squealing noise.
exp500
Have you checked for a loose/corroded PCM connector or similar ground? Intermittant failures are tough to trace when everytime you touch it it works. The only positive is your possibles list is getting shorter.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I should have updated the post... Thanks for tip...
Looking like it was a bad junction / fuse block. I replaced it moved pump supply relay to outside of junction block. Haven't had problem since. Also it got rid of heating in junction block as I think the current draw from aftermarket pump wrecked the original fuse block
bigb901
