Oil pressure sensor HELP!!!! - SOLVED
Los Angeles, CA
The valley cover looks like an LS2 cover. Is that a 6.0?
When I did the DOD delete I noticed the LS2 cover is shorter and thinner so a screen wont fit in there. The VLOM is thicker and taller to give the screen space
S
Spencer4991
All right, few days later update there wasn’t a filter in there put a new oil pressure sensor in went and got some engine. Flush ran that through the engine. Did an oil change still low pressure finally listen to what everybody has been saying about the O-ring on the pick up tube inside the pan and went ahead and changed it l…. That was exactly the problem now I’m getting 19-25 idle psi and 40-55psi driving
AChevyKing
