Head unit recommendation
When I was on crutchfield looking at the kit, seemed like I was loosing a couple things. Mainly the rear entertainment.
Obviously the satellite radio and navigation won't matter anymore. But my kid does use the rear entertainment and the DVD player.
I don't know of any adapters that retain rse on the k2's, your best bet is to upgrade the radio to the latest ios and if you want wireless android auto/carplay you can use usb adapters that work very well for that. you can also have the hmi programmed to allow for video in motion if so desired.
there are also usb "magic boxes" that allow various video content on the screen like youtube, etc.
fatmonk8
fatmonk8
Yeah, I actually did this.
It's more because my screen is dying and I'm looking at options before I just replace it.
Plus that method renders the steering wheel controls useless for AA/CP without upgrading the cluster or programming it.
And for that extra money, I could just replace the radio to a better one imo.
my steering wheel controls work with android auto and a motorola ma1 just fine
and I have the hmi fully unlocked and added factory nav
I just don't have rse (pickup)
might be different if it is a 2015 though
fatmonk8
fatmonk8
Interesting, what year do you have. When I got the replacement modules and got them programmed, I was told swc would not work and I need the new cluster or to program mine.
if you want to just upgrade the hmi for android/carplay you can buy a used hmi and use a obd genie to unlock it to your vin, that would run you about $200-250
mine is a 2018 and the wifes is a 2016, we added the ma1 to hers also and it works just fine.
what year is yours?
fatmonk8
fatmonk8
what year is yours?
I have a 2015, that's what I did. I got used ones and got them programmed/unlocked.
So I have AA, just not controls
I have a 2015
tooleyondeck
Northwest FL
That PAC kit will retain SWC. I was unaware that your front RSE screen had the blu-ray player in it (I thought it was in the head unit). You can easily replace the factory RSE for a larger screen, that's what I did (albeit mine is a GMT800 so it was simple). I have 2 7" dvd headrests and 17" fold down all linked and audio out goes to my carplay HU.
when I added factory nav and unlocked the hmi I think the only thing it does not do is add the "nav" display option on the cluster, even though it is pretty much fully synced to my vehicle.
when I select nav in the cluster it just tells me it is for "factory nav" but factory nav does work on the radio. I never use it and it is just there for redundancy I would have to go try and set a destination and see if it shows up in the cluster which I think it doesn't
fatmonk8
fatmonk8
Thinking this might be the way I go. Just replace the rear entertainment to work with the new head unit.
That rear roof screen is pretty dated anyways.
beres8998
