Engine Oil Overfill
Eddie_Tahoe
Hey all. I drove home from a regular oil change and didn't notice anything unusual but next day saw oil level was a little high (at about the R in "OPERATING RANGE" on dipstick, see picture). Service invoice says 6qt went in. Took a short drive, pressure seemed higher than normal (about 50psi), slowly dropped to around 25psi steady as truck warmed up. Should I be worried, try to drain some out? THANK YOU!
Super Moderator
Elev 5,280
Did you read the other side of the dipstick? It might show a lower level; always use the lower level reading. And be sure to read it with the vehicle on a level surface, with the engine not having run for 10 or 15 min to allow the oil to drain from the upper engine.
homesick
The Best Me I Can Be
That invoice also tells you they pumped in oil and never checked the level. Idiots!!!
You need to get some tools and a drain pan and do it yourself.
... and check it each time, before you leave their facility.
I have no disagreement with Fless' post but, in my experience, his recommendations are for reading and adjusting in finer increments than what you're dealing with here; especially if they've over-filled you.
If GM's gone from 5 qt capacity to 6 qt capacity, over filling an older engine just gets more likely.
joe
Super Moderator
Elev 5,280
joe
Unlevel ground can make a difference, too.
Silentnight008
