@Marky DissodI'm always baffled by those who don't disable cylinder (valve) deactivation first chance they get.
@Marky Dissod
This is a very interesting comment. So there are no downsides in your mind to disabling? Even with a knock off China dongle? (No emissions tests here)
I've searched, not too hard, but never really got an overwhelmingly obvious answer.
Also, see my comment above about weird failures I had, if you'd be so kind. Could be more to do with M5 than the actual disabling though.
Thanks!
@j91z28d1check your motor mounts. 90% of the time they are broken letting the engine move around. it's harder on things
Ha, 'nuff said!I bought mine used in FL and brought my laptop with me to disable it with hptuners before I drove home. I wasn't going to risk the drive home with it on.
@j91z28d1
They look pretty good...I think? Not really sure what to look for besides broken rubber. I'm not noticing any of the classic symptoms. It moves a little when it's idling and you have someone hit the gas. I thought that was normal movement.
I did have a bit of a bouncy idle, but when I cracked the PCV vacuum line when replacing the oil sender, the new one seems to have solved that problem.
Thanks, I will check it out! Some of the threads are so long it's a real time investment to wade through them...there's a motor mount sticky in the engine;drive train sub forum. near the end is a video clip of broken mounts. to test you gotta be in gear and give it gas while someone watches the engine move. it's the tq of moving the vehicle that makes it lift
Disabling is not as good as deletion, but it's a good start.
Long story short: no, no downsides to disabling it.@Marky Dissod
I've unique experience among most of you. Had my GMT900 tuned to INCREASE V4 mode duty cycle,
made it available as early as 20MpH, in 3rd 4th 5th AND 6th.
Had my GMT900 tuned to INCREASE V4 mode duty cycle, made it available as early as 20MpH, in 3rd 4th 5th AND 6th.
I was (and very occasionally still am) a taxi / livery driver / chauffeur for hire in NYC.Gotta ask, why did you do that?
