Truck Broke, need help....
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
A battery can only do so much, the stock alternator is only 105 amp, you should look into at least a 145.
JKmotorsports
Austin, TX
Whoa...your dash looks pretty f'ing bright there man with all those lights. Sounds like what Jenna already stated; the modules lost communication with each other. I know you said you already tried disconnecting the battery, but try it again. Remove both positive and negative, then turn your key to the ignition position for a second or two to make sure any stored current in the modules are gone. Let it sit for about 10 mins then put the cables back on the battery and see if that helps any.
Rollin Thunder
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
even with a cap im going to have issues??? Does the stuff draw constantly?? Cause even with everything off it still gave me fits. I have no trouble with lights dimming or anything.
Tinkerer4
