Problem was not fixed..
X
XxBIGxTEXxX
ok thanks... Now i think was reading somewhere about t-case fluid gets transferred over to rear gears on its own.. is this true?
Since i added the performance clutches/shift kit/servo to trany and i think they added regular cheap trany oil, would u recommend flushing it and going with another type of fluid as in like a synthetic or something.. if so, what kind of oil would u recommend?
X
XxBIGxTEXxX
Is their one clamp for both of the axles to come out or is their 2 C clamps...? One for each clamp...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
one c-clip for each axle.
---------- Post added at 06:35 PM ---------- Previous post was at 06:31 PM ----------
Since i added the performance clutches/shift kit/servo to tranny and i think they added regular cheap tranny oil, would u recommend flushing it and going with another type of fluid as in like a synthetic or something.. if so, what kind of oil would u recommend?
:lol: No not unless it travels thru the drive shaft.
There was at on time an issue where the tranny fluid was leaking thru the output shaft seals into the t-case. So the tranny level would go down and the t-case would overfill and spill out. but a TSB was released for that.
---------- Post added at 06:35 PM ---------- Previous post was at 06:35 PM ----------
just use dexron 3 in the tranny.
X
XxBIGxTEXxX
Ok.. Its all done and ill get tomorrow and take it in a drive and see if anything happens.. I did put a new seal and new bearing. Some thing i did notice is that on top of where the bearing is located inside, when i ran my fingers in there and felt around the inside differential housing case, i felt a bent or like a wedge since i did get hit back in 2007 when some idiot ran a stop sign and since my sis was in the passenger side, the hit was going to be directly on her door and i stepped on the gas and tried to see if i could prevent the other car from hitting me but he ended up catching me and hitting me right on that rear right side tire. It spund me around causing me to be facing the opposite way and half of the other person engine ended in the front and destroyed. I was able to move my truck and the only thing that got bent was the axle which it got replaced... Since then, i have never notice a leak of any kind on the rear differential tires at all... Till now. So maybe that hit bent the actual differential housing case just at that spot.
What i did once the new bearing was place inside; i grabbed a flat head screw driver and right on the edge of the bearing where it touches the house casing i slowly placed it and tapped it in with a hammer all the way around where it could stay real tight and tried pulling it out and never came off.. Lets hope that works.. Since i know that the differential case is actually bent right there and if it stops the leak, when i get my lift installed, i wll get a new one with better gears...
X
XxBIGxTEXxX
Dang it... or why didnt i think of using the old one and sliding that one in after the new one and just hit the old one with the hammer.... lol
But im sure ull see a new thread about a new differential assembly soon and what to get...
SunlitComet
OBS Jedi-Do Good
It is not really if it is big enough. I mean that it is important but more important is that it goes in evenly so it does not bind up and seats flat.
claymaloy
