Toration bar keys and noises wtf?!
Cocotits
Bay Area CA
So I just replaced all 4 corners with bilstiens and installed my rear hardware kit from tony. Also replaced my shocks with the new beltech 4" trailblazer springs. Also installed the helper bags with them. I used a touch of wheel bearing grease for my away bar struts (all that was on hand). Everything went smooth and the truck rises great.
Measurements:
Fd-32.75"
Fp-33"
R-33.5" both sides
Week later I have noises. Squeaks n clunks everywhere. I noticed my torsion bar keys were adjusted way differently when I was down there. The driver side is actually almost fully threaded in, which would lift the fd side up almost to its max height adjustment. I have about 1/8" of thread left for adjustment up. The passenger side has about 13/16" of adjustment left to go up. Big difference and as I mentioned before what my wheel well measurement was: fd-32.75" fp-33". Weird right??? When I installed this lowering key kit year n half ago I cut the top cone off of the bump stops. On two cones left and sitting down as it is adjusted I have about the clearance of a business card on my driver side. The passenger side is a hair more as it is higher.
See my problem here. No travel and no room for adjustment.
Help
NoPh33rRaCiNg
Kent, WA
My torsion keys are way off as well. I think all are like that. One is maxed out the other is not. I'm not too sure about the squeaks hopefully someone else can chime in here soon.
Cocotits
Cocotits
Bay Area CA
Thanks man. Really thats interesting. I hav heard of the"Chevy lean" but never thought it was so drastic with the keys adjustments.
Yea Tony what do you do about squeaks??
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
And do you ever get clunking noises?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
sqeeks are coming from front or rear?
Cocotits
Cocotits
Bay Area CA
Squeaks seem like they are comin from the rear. The whole rear hardware kit and helper bags. N I have clunks I didn't have before. Can't tell where they are comin from I'll have my wife idle around with me searching today n get back with more serious info.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ok in rear you have teh djm relocation kit of the trailing arms and the swaybar?
Did you move the swaybar over 2 inches like instructions show?
The swaybar should be on the inside of the driver side endlink and on the outside of pass side endlink.
Did you cut the bumpstop brackets off the frame?
On the spring did you use the rubber pads on top and bottom?
Cocotits
Cocotits
Bay Area CA
Tony all of those things were done. On sway arms I used wheel bearing grease on faces. Top and bottom. I moved over like instructed. No grease. Trailing arm brackets installed and TIGHT. Rubber pads for springs were slighted cut up from I'm guessing not being quite in place right on last springs. Have four new ones on order as they did not have them in stock. But they seemed to do the job for now. Feels like the sway could be some of problem. But how to I fix tighten or loosen? Helper bags I installed have no pressure in them.
Most sounds I get are when I brake. AND it's always after I hit the gas. If I brake twice I only have sound the first time till I hit the gas again. Haven't pin pointed it yet. Wife no help lol.
---------- Post added at 10:56 PM ---------- Previous post was at 10:50 PM ----------
But if I'm Rollin on uneven turf. It get squeaks too, so hard to tell while idle strolling but I wanna guess sway. But if that was the case I can't be the only one with a problem.
Cocotits
Cocotits
Bay Area CA
Do bilstiens make hella noise? Any special steps need to be take with their installation?
Dizigidy
NorCal
While installing djm trailing arm brackets, did u leave the bolts loose untill the truck was back down on the ground at normal operating angle/range, then tighten? Maybe the rubber bushings there are all twisted and/or torqued up.
I don't know about Bilstiens making noise, but curious to see what others say. Good luck buddy.
ROB28
east los angeles
I've had djm front lowering a arms for a about a year and started getting squeeks about a week ago in the front left side I think its the torsion bar . Any one have the same problem ?
Tssonebay
