NNBS Kelderman air suspension kit
Status
Not open for further replies.
yates ™
Resident Apple hater
Iowa
So at comfortable ride height it's still super raked?
You could set the back down to even out but I would recommend getting brackets norcal sells for the shocks. I think I had my front and back set a little lower then the 2".
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I just so happen to have the DJM rear shock/sway bar relocator kit as well... If the buyer wants those parts in addition to the Kelderman air suspension I'm sure we can work out a deal.
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I was really considering just doing the REAR in airbags and the front on drop struts.
so 2 bags in the back and the brackets, one tank and compressor
To help me re-coop as much as possible from my investment I have to keep the tanks as a pair and same goes for the pair of compressors. Shoot me a PM with offer if you'd like the rear bags with associated brackets.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
bidding on all 3!!!
Goodinblack
I Like Tacos
Dirty South
So to those that know........
It seems this kit would only control all four corners...... Since I would like to do only the back what options is there to control it?
When the back is at ride height, which is 2 inches lower than stock........ what should the PSI be in the bags?
Also, If I did manual fill, how much air do the bags lose every day, just sitting?
yates ™
Iowa
In order to run the back bags with any type of controls like how this works you would still need a tank and a place to put the compressor/s and one of the different options to run just a 2 corner system.
I honestly have no idea how much PSI is in there it would be something you would have to play with to find out but you could T the bags together which I would recommend or you could fill each bag manually.
They shouldn't lose any but the possibility is always there.
GalaxyBlackEsky
BlackedoutLT3
MD
HOLY Shit did that full kit only sell for 1400?? If so I would have bought it for that much!!!
Status
BruceWayne
