New (Used) Escalade owner
N
Nbs
indeed, LOL :chewie:
if i started counting i'll probably be depressed, i stop counting after 5K, lol and yes WORLD of a difference when i went from stage 1 to stage 2
So do you think your "Stage 1" (Cold Air Intake, Exhaust, Long Tube Headers, NO Cats, Corvette Servo/ Billet 4th Servo And Custom Live Tune) was a good first step?
Or is there anything you would have done different?
Phantomx55
Slow
New Jersey
"Stage 1" is a good idea to start, I wouldn't bother with the 4th gear servo though.
For my example, a stock 5.3 Tahoe should run mid to low 16's. After LT Headers, no cats, exhaust, intake, e-fans, and tune I ran a 15.656 @ 88 mph with a 2.36s 60' on my heavier 22's.
After I installed a better built 4l60e trans and a 3400 billet stall my times dropped to 14.940 @ 89 mph with a 2.09s 60' back on my stock rims.
And finally after the procharger and cam my times dropped to 12.503 @ 105 mph with a 1.68s 60'.
Though any of your numbers with the same mods should be better with the bigger 6.0
N
Nbs
Essentially I want to drop in to the 15s with my first "stage" and then drop a second with each additional stage. My ultimate goal is to be in the 12s!!!
Phantomx55
Slow
New Jersey
Stock you are probably already breaking into the 15's and with everything labeled in stage 1 you will probably be into the 14's.
Travieso
Boooooooost !
Los Skandeles, CA
i went stock with 24's on the 1/8 mile an embarrassing 10.4
With "stage 1" it went on the 1/8 mile 9.7
"Stage 2" With 24's it went on the 1/8 8.4
With Race Fuel and stock Tires i'll break high 12's
---------- Post added at 04:37 PM ---------- Previous post was at 04:33 PM ----------
Stage 3 should get me in the 12's for sure.
bobbywdatool
