Few irritating problems
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
I have a few problems that are really starting to piss me off. The truck is a 1995 Tahoe with 191k on it. First, my truck hesitates upon acceleration. It bogs down when I accelerate for a couple of seconds then picks right back up. Second, when lightly touching the gas to maintain a speed, the trucks starts to jerk back and forth until more gas is given. Third, when I let off the gas, it kinda makes a bhaw bhwa bhwa sound about three or four times before it settles back down.
I have replaced all spark plugs, wires, cap, rotor, and TPS sensor with all AC Delco parts. I have also checked for vacuum leaks, which is a negative. The EGR valve operates like it should. All of this was done a couple months ago and has no more than 2k on it. I'm out of ideas. Coud it be fuel related? Anybody care to help me out before I blow money having a diagnostic test done at a shop?
haks310
Got LEDs?
SoCal
Sounds fuel related to me. Start of by checking your fuel pressure. Hows the spray pattern on the injectors?
96ProCompTahoe
IN
you cleaned the MAF sensor yet?
my camaro does the same things (though it has a few other more serious problem)
Bad bow tie
Bad bow tie
Michigan/NC
Does the TBI have a MAF? I thought only the Vortecs had those...
Thinking I will check the IAC and the fuel pressure. What's the pressure supoosed to be?
haks310
Got LEDs?
SoCal
TBI has the MAP sensor. Vortec has MAF
Pressure should be around 9-13psi.
Twenty4s
Banned
it's the fuel pump. check the pressure at the rail. mine did that a couple of weeks ago and it was fuel pump. change the fuel filter first.
Bad bow tie
Bad bow tie
Michigan/NC
Could it be the MAP sensor? I have read that it causes hesitation and fuel delivery problems.
---------- Post added at 11:26 PM ---------- Previous post was at 11:25 PM ----------
Fuel filter has been changed.
haks310
Got LEDs?
SoCal
Could also be the MAP, it adjusts the timing and fuel depending on vacuum conditions.
Are both your injectors spraying a nice cone?
Hollys Denali 805
