Few irritating problems
Bad bow tie
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
would it not set a code?
also want to add could it not be your timing chain is getting worn out?
I have no codes...ever. The "check engine" has never come on. I don't think it is burned out because it comes on when I turn the ignition on.
Checked the timing a couple month ago when I was trying to fix these problems.
haks310
Got LEDs?
SoCal
Just start up your truck and point your timing light at your injectors, both should be spraying out a nice cone of fuel.
Also..check your coolant temp sensor and check the wiring for it. Make sure it has not been damaged.
sc00bz
South Paw
check/clean MAF sensor, change fuel filter if it hasn't been done recently (sounds almost like you have to force gas through the filter to get it to run correctly), & last but not least (and probably the problem) check the fuel pump.
haks310
Got LEDs?
SoCal
LMAO TBI does not have a MAF! It uses a MAP sensor. And he mentioned that he just changed the fuel filter.
ravingmadman
Chief Knuckle Buster
Greater Seattle
If it were carbureted, I'd say after changing the fuel filter, lighten up the springs on the secondaries on your carb. Lol. I've got little/no experience with TBI though, so I can't tell you what to do to make the same effect.
pacman1981
sounds like fuel pump to me, had that prob wit a 94 full size blazer i had, i would check the fuel pump out
1999hoe
aka HOVERHOE
Massachoochoosetts
tpi......or possibly the fuel pressur regulator get some cleaner down the throttle body also get some seafoam in that bish!!!!
drackill1
