Best coil pack replacement?
M3kanic
Check the trunions.
Sent from my SM-G900V using Tapatalk
M3kanic
Do you know why the rockers are loose?
JubjubW
JubjubW
Wausau, WI
It's normal after I read up.
Honest question. Could a bad maf cause this? I unplugged it with no change. Also I cleaned it and watched it get shiny. I have a kn filter
Sent from my SM-G900R6 using Tapatalk
M3kanic
I have heard of it happening. I have personally never had that problem and I have ran K&N in all of my vehicles for many years.
Did your plugs look clean when you changed them out? (Oil consumption?) Have you ever changed out your intake gaskets?
JubjubW
JubjubW
Wausau, WI
No need for the intake gasket. Perfect compression from there to the cylinders.
M3kanic
When I tuned mine I wasn't throwing any codes but they could see a massive leak. This has me stumped.
JubjubW
JubjubW
Wausau, WI
You're not the only one. I have no power from a stop, the miss drives me nuts. Can't pass. Baby her on the highway.... Idle seems a little rough. Idk
M3kanic
Alot of people are saying maybe a cam, crank, or knock sensor.
JubjubW
JubjubW
Wausau, WI
I was looking for a cam sensor. Where is it located
PV90274
