jdwood1111
- Joined
- Jun 16, 2022
- Posts
- 115
- Reaction score
- 144
Hey All,
As part of my ongoing slow maintenace I finally had time today to change the belts and pullies (AC Delco kit from RA). It went very smooth and got the AC stretch belt on with the zip ties no problem. After I started it up it sounded a little different than normal but I have not run it with the hood open in a while so I wanted to post a video and see if this is normal sounding operation. It was not cold but not hot. Temp was on the colder side to in the middle as I had run it a bit earlier today and it sat for a couple hours. The ticking sounded did not sound like it was coming up but rather from the bottom. Let me know your thoughts if you don’t mind. This is more first ever truck and GM product so I don’t have a lot to compare it to. I took it for a ride after and it rode fine! Actually felt a little peppier. All I hear inside the cabin is the exhaust (stock) and airaid for the most part.
No check engine light, 45PSI oil pressure, good voltage, Range AFM device, no other known problems. 95k miles and I have already cleaned the throttle body, mass air flow sensor, new air filter and all other fluids except coolant & transmission (working on both of those).
Thanks!
EDIT: Here is a video of it after i got back with a hot idle but the fans were on so its harder to hear.
Thanks!
