tenminutes
- Joined
- Jul 2, 2014
- Posts
- 59
- Reaction score
- 72
Oh my god, how clean. It seems that the car was just bought and did not go on the roads)))Honestly if I had it to do over I’d probably save the $$ and just go the zip tie route. As far as the ride goes, it’s just as smooth as stock and the recon grapplers are really quiet. (Don’t mind the bags on the lift pads, the undercoating GM uses on the frame is some nasty stuff)View attachment 402057View attachment 402062View attachment 402058View attachment 402060View attachment 402061
Im having issues with my 21 Z71. It’s identical to yours with same tires and same rims. I put the 3.5 RC lift and to fit the 285/55R22 i had to go with a 1-1/4” spacer because the RC control arms hit the tires. This cause serious rubbing. I’m thinking of going down to the 2” to do away with the RC arms and would also do away with 1-1/4” spacers. My guy installing says the rubbing will be too bad and we need to go down to a 285/50R22. How bad is your rubbing with the 285/55? I really do not want the 285/50.
Update: Added 1.25 HC spacers. A small amount of additional trimming but still not to crazy at all.
View attachment 365785View attachment 365786View attachment 365787View attachment 365788
Probably not the struts, it’s the upper control arms that are hitting your wheels without the spacers. I’m running 2” RC, 1.25” spacers, stock size tires and had to remove the brackets behind the fender liners and do a little trimming. Did you remove the brackets?You had less rubbing with 2” lift and no spacers? What made u put spacers? I’m thinking about going down to 2” lift to keep factory struts and removing spacers. My guy installing thinks that will make the rubbing worse.
