2021 Tahoe PPV massive oem brakes, 16"
wildchev67
This thread is great for info, thanks all! In the last month I have swapped my 2011 Escalade, and 2024 Yukon.
Below is the list of what I used for my 2024 Yukon swap. The PPV j55 Tahoe has different brake hoses listed, I have confirmed those fit. Also as stated before, the rear wear sensor works for the front calipers.
I ended up customizing a 18mm socket so I could remove the hub bolts without removing any ball joints, just need to tap the axle back a little.
I will keep an eye on brake dust, I believe it was said the Brembo pads make a lot of dust? My 2011 Escalade has power stop pads, so I should be able to compare.
PPV J55 2021+ brakes:
16" Rotor weight 87839222 40.8 pounds
6 piston caliper 84793057 weight w/pads 19 pounds
2021+ SUV standard brakes:
14" stock rotor 29.2 pounds
4 piston caliper w/pads and brake hose 19.8 pounds
GMt900:
13" rotor 25.4 pounds
2 piston caliper and bracket 18.8 pounds
2021 PPV j55 Tahoe, VIN to use 1GNSCLED6MR283980
GM GENUINE
84793057​
Caliper (Drivers Side) Brembo​
GM GENUINE
84793058​
Caliper (Passenger Side) Brembo​
GM GENUINE
11569590​
Banjo Bolt x2 ( M10x1)​
GM GENUINE
21012386​
Banjo Bolt Washer x4​
GM GENUINE
11546469​
Caliper Bolt x4​
GM GENUINE
84495310 (84763236)​
Brake Backing Plate (Passenger side)​
GM GENUINE
84495309 (84763235)​
Brake Backing Plate (Drivers side)​
GM GENUINE
84688287​
rear pad wear sensor (longer lead and reach on sensor end)​
GM GENUINE
84987498​
Front Brake Pads (Heavy Duty, hardware not included) Brembo​
GM GENUINE
87839222​
Front Brake Rotor (Heavy Duty) x2​
GM GENUINE
86555794​
Caliper hardware kit (pins and pad spring plate)​
GM GENUINE
84956404​
Front Left J55 brake hose (w/banjo bolt and washers)​
GM GENUINE
84956405​
Front Right J55 brake hose (w/banjo bolt and washers)​
alternativeNapa
FLT FT9637​
Fleet brake pad (includes caliper hardware)​
alternativePOWER STOP
AR82209XPR​
Rotors (both sides)​
Z37-2407​
Brake Pad (both sides, pins included)​
RTLINGR2
Sanford, Fl.
Hey everyone, just giving you all another option in replacement pads and rotors. The Power Stop brake rep came by the shop the other day. Set us up with a complete set of front and rear pads and rotors for 21 and up PPV Tahoes. These are supposed to address the brake squeal and increase the wear mileage over the OE pads. We haven't installed them yet, so we don't have any data to report. Just haven't had a tahoe that need a brake replacement yet. Here are the part numbers and the hardware the front pads come with.20240508_112809.jpg20240508_112842.jpg
Twov8sandat4
I installed the exact combo of pads/rotors you have in those pictures on my 07 Escalade. I have to say I have never seen so much brake dust in any of my vehicles. The stopping power is phenomenal though.
I am going to change pads to something with low dust when it's time to do the rear brakes (soon) and have matching front and rear pads.
Thanks.
RTLINGR2
Sanford, Fl.
Thanks.
Thanks for the heads up! I will keep that in mind for our fleet.
Now, on my 04 2500 sub installed Wagner OEX pads all 4 corners. Stock rotors. They stop good with and without a trailer, low to no dust and quiet. They were advertised to knock off additional 50' stopping distance. These have been on for a while, but I'm not ******* brakes, they wear very good. When they do wear out I will buy them again. When the pads wear out on my Tahoe, it will get the OEX's also.
Now I have not checked into If the OEX's are available for replacement on the ppv. If they are, I would try them.
Twov8sandat4
That's good to know. My plan was to do EBC yellows all around as I wanted to install C7 calipers in the back, but if there are other pads, I am open to it.
Thanks.
Jimbo123
Hey everyone, just giving you all another option in replacement pads and rotors. The Power Stop brake rep came by the shop the other day. Set us up with a complete set of front and rear pads and rotors for 21 and up PPV Tahoes. These are supposed to address the brake squeal and increase the wear mileage over the OE pads. We haven't installed them yet, so we don't have any data to report. Just haven't had a tahoe that need a brake replacement yet. Here are the part numbers and the hardware the front pads come with.View attachment 428044View attachment 428045
I did swap out to these pads. WAYYYY less dust, no squealing, and overall very happy. They grip a bit less than the original semi-metallics that you posted, but it's a land yacht, not a sports car.
Malachismith
