mountie
... somebody should snag this. Seems like a great price to me and very clean for the year:
On the SURFACE, it seems "very good"......
I considered an '81 Honda 900 motorcycle.... Pictures were 'very good'... in person, it may have been stored in salt water...... ( Just saying, considering the price offered )
latvius
Ariton Alabama
OR somebody could just want it gone and doesn't want to field 3000 "is this still available" posts. You never know which is where all the "barn find" stories come from. :)
mountie
I agree...... It seems to look good, for the selling price, ..if it needs fixing, it could be a good price still. ( One observation..... The color of the carpets..... They look darker than I would expect with the interior color.... Uh, I have seen "good looking" used cars, that were in a flood. ??
strutaeng
Dallas, Texas
Well, looks like it sold quickly, so I would say, yes, it was a good deal... :)
Gmg0547
I threw in new tie rods, inner and outer tonight. The hardest part was breaking the inner one loose. One thing that I thought was weird is that the passenger outer came off with 16 turns while the drivers side took 30. Is that normal or should they be closer? I was thinking they would be relatively the same. Just have to torque everything and grease.
I bought a complete steering column with steering wheel and key. It has the factory steering wheel controls. Mine doesn't. It's just an LS model. Would it be better to swap out the entire column in my 03? Would I run into any passkey issues causing it to not start? Or could I get away with doing just the steering wheel--with the controls, along with the correct clockspring? I did get the complete column including the column harness. I'm just interested in getting into the options that it'll give me.
Anyone?
Bueller? Bueller?
Ya know,, I don't know what can o worms you'll find with a different harness, and how to attach??
I agree. I just need to start digging in--see what I find. Hopefully there's no programming or anything else involving the bcm.
mountie
I'll be doing the same, plus the new front Hellwig sway bar.
A shop just down the street, will be installing my front Hellwig sway bar & rear shocks next week... They'll charge only an hour labor. ( ( They do a LOT of this stuff, so they can do it fast & clean)
TahoeZ71_05
Removed and disassembled my headlight/interior lamp switch on my Z71. I was having an issue where as I was driving, the instrument panel and radio backlight would turn off, I could bump the switch or the adjustment wheel the lights would come back on. Cleaned up the board and all contactors inside the switch, works like new now, I guess after 300k+ miles things got a little sticky inside.
Malachismith
