Burban22
Found some $100 original snowflakes on marketplace. 295/70/17 used set of BFG K02 $200 marketplace. 33.3" overall diamater. Date code 2020 but a good amount of tread left. Load range E so kinda stiff. Probably lower psi from 55 to 45. Added some black 19mm lugnuts and wheel caps. I did the 1.5" rear coil space awhile back along with 2" front torsion key lift. These fill out the wheel wells nicely. IMG_3202.jpeg
Burban22
FYI - if running 295/70/17 on stock wheels you’ll have to trim some rear fender liner where it sticks out around the top shock bolt. Also had to turn around the shock bolt so the nut faces inside as the tire is super close to the shock tower.
mountie
After installing the Hellwig rear sway bar & front Bilstiens, Today, got the Hellwig front anti-roll bar & rear shocks..... Feels pretty good.... I heard, it takes a few miles to break in the new shocks...
I had it done, at a NICE custom truck shop..... They charged only an hour's labor. ( since they do this sort of stuff every day) " Farm Boy Customs "
S33k3r
Dallas, Texas
Welp... I may have done a thing today...
It was sold as 200k miles, but it's actually 226k. Still runs nice. Likely needs a transmission rebuild, but that was disclosed before I bought it. AC seems to be dropping water into the passenger floorboard. Gotta figure out what that is all about. But it saved me $500 on the sale. I'll register it tomorrow and see what the taxes are on it. But I bought it for $3k. I'm fairly sure I could part it out for $4k - $5k, if I had to. Hope to get another 100,000 miles out of it, though -- after having the transmission and AC drains checked out. The driver's seat isn't even ripped up. And it's a Platinum edition; that includes heated and cooled seats, front and second row plus heated/cooled cupholders up front.
Keviebear86
I ordered new tires today. I work at a Bridgestone tire dealer so I preordered the new Bridgestone Dueler AT Ascent in a 305/55R20. I'm currently using 275/60R20 Bridgestone Dueler AT Revo 3. I'm guessing I'll have to trim my inner liner a bit, which isn't a big deal. Hoping to get my HD hood painted and installed before winter as well.
S33k3r
Dallas, Texas
Dropped the Escalade off at my regular mechanic. This was to get a second opinion on the items I already diagnosed and get an oil change. He's going to call me, tomorrow, with his opinions.
I dropped the Suburban 2500 off at the mechanic that has been doing electrical work for us to replace the knock sensors. They told me they are way backed up, but they would work me in between jobs if I could leave it with them.
Pnut
