DEF level sensor issue
JayceeP
There is a TSB for DEF level errors on GM trucks and SUVs. I think the TSB is 22-NA-150 (it's been updated to add new model years several times). It's a software update.
The level sensors in the DEF tank work the same way water & waste tank levels are in an RV (not very accurate). You can't have a float since the DEF is allowed to freeze in the tank.
Thanks any thoughts on why the low DEF warning is only showing in the app and not the truck itself? Current DEF gauge has all but 1 bar currently in the def level screen.
Jay P Wy
Natrona County WY
Nope, but our Tahoe oil life in the app sometimes doesn't match what the dash show (usually when below 40%). For me the app only tells you if the DEF level is good or not. If you aren't seeing any issues with the vehicle itself I would ignore the app.
Jay P Wy
Natrona County WY
FYI. If you have a Banks iDash or Edge CTS3 you can monitor DEF level and you can see the level bounce around when stopping or starting but remains pretty steady when vehicle is steady state on level ground (unlike the factory dash gauge which doesn't move much).
JayceeP
Haha I like that approach!
JayceeP
Yeah, I think it was when I dropped my son off at camp this morning. It’s a very steep exit from the parking lots and that’s when I randomly had the distance to DEF empty (I’ve never seen this before…. Would be nice to have it all the time) and I could dismiss the message. I left the message up and it steadily increased as I drove and then after a minute or so it stopped at approx 2,000km/1,250mi to empty DEF. Then I dismissed it and it hasn’t been back since. But it was at that time I got the message on the app of DEF Range Low and it hasn’t gone away yet.
I’ll keep an eye on it thank you!
Dremar79
