Weird rattling noise coming from engine bay
Brizzzy
Rattling noise in engine bay - 2011 Tahoe 180k miles on this engine
Does anyone know what the is rattling might be? It just started on my 2011 Tahoe. It also continues for a couple of seconds when I turn the truck off. Seems to be at least somewhat intermittent because I have turned it on and off a few times and at the moment it’s not making that sound. Sounds concerning. Any help is appreciated!
Geotrash
Dave
Richmond, VA
Thanks for posting the video. The only things that may stay turning after you shut off the engine are the cooling fans. Give them each a twirl (with the key in your hand) and see if either of them are the source of the noise. Ba careful though because the fans can still start with the ignition off and key out.
j91z28d1
huh that sounds kinda solid.
I can't even guess. probably have to go thru the motions. pull the accessory belt off and see it for t goes away type thing
take the belts off and give everything a good spin by hand, or go grab a stethoscope and listen, shouldn't be hard to find
BrancoRST
