wildchev67
- Joined
- Jan 7, 2024
- Posts
- 7
- Reaction score
- 6
This thread is great for info, thanks all! In the last month I have swapped my 2011 Escalade, and 2024 Yukon.
Below is the list of what I used for my 2024 Yukon swap. The PPV j55 Tahoe has different brake hoses listed, I have confirmed those fit. Also as stated before, the rear wear sensor works for the front calipers.
I ended up customizing a 18mm socket so I could remove the hub bolts without removing any ball joints, just need to tap the axle back a little.
I will keep an eye on brake dust, I believe it was said the Brembo pads make a lot of dust? My 2011 Escalade has power stop pads, so I should be able to compare.
PPV J55 2021+ brakes:
16" Rotor weight 87839222 40.8 pounds
6 piston caliper 84793057 weight w/pads 19 pounds
2021+ SUV standard brakes:
14" stock rotor 29.2 pounds
4 piston caliper w/pads and brake hose 19.8 pounds
GMt900:
13" rotor 25.4 pounds
2 piston caliper and bracket 18.8 pounds
2021 PPV j55 Tahoe, VIN to use 1GNSCLED6MR283980
GMt900:
GM GENUINE | 84793057 | Caliper (Drivers Side) Brembo |
GM GENUINE | 84793058 | Caliper (Passenger Side) Brembo |
GM GENUINE | 11569590 | Banjo Bolt x2 ( M10x1) |
GM GENUINE | 21012386 | Banjo Bolt Washer x4 |
GM GENUINE | 11546469 | Caliper Bolt x4 |
GM GENUINE | 84495310 (84763236) | Brake Backing Plate (Passenger side) |
GM GENUINE | 84495309 (84763235) | Brake Backing Plate (Drivers side) |
GM GENUINE | 84688287 | rear pad wear sensor (longer lead and reach on sensor end) |
GM GENUINE | 84987498 | Front Brake Pads (Heavy Duty, hardware not included) Brembo |
GM GENUINE | 87839222 | Front Brake Rotor (Heavy Duty) x2 |
GM GENUINE | 86555794 | Caliper hardware kit (pins and pad spring plate) |
GM GENUINE | 84956404 | Front Left J55 brake hose (w/banjo bolt and washers) |
GM GENUINE | 84956405 | Front Right J55 brake hose (w/banjo bolt and washers) |
alternative | Napa | FLT FT9637 | Fleet brake pad (includes caliper hardware) |
alternative | POWER STOP | AR82209XPR | Rotors (both sides) |
alternative | POWER STOP | Z37-2407 | Brake Pad (both sides, pins included) |
