seats.
beatup01
DFW, Texas
I'm looking to get specifically my driver's seat repaired/replaced, and i was curious, should I just go to a junkyard and find some seats, should i just get covers, or should i reupholster. im trying to find the best solution money isnt an issue
Welcome to the Forum from NH.
Pics of the truck, please.
I suggest that you check out the Seat Shop, where you can get a replacement foam cushion and the leather cover.
Tahoe14
Central Fl
You could go to a junkyard but they are probably going to be worn like the ones you have. I would reupholster it and install new pads while you have it out and apart.
Tonyv__
Bucks county PA
I bought this years ago and was very happy with it. The listing is still active. I don’t have the truck anymore to tell you how it looks today. I recommend getting the cushion as well, also obtainable on eBay.
beatup01
beatup01
DFW, Texas
here are some pics, and i will check that out!
I'll have my Hoe for a good long time and got my stuff at The Seat Shop a couple of years ago -- new OE style bottom cover, seat cushion, and heater pad. If you don't use the seat heater you could get by without a new pad, but getting the old one off (and assuming it's in good enough condition to last, and it survives the removal) will be a hassle.
Pics of my work here:
You can get by with less expensive parts if that's the way you want to go. Others will have some less expensive suggestions.
jack004
