$18K Repair on 2010 Burb? Yup, it made sense.
petethepug
Michael
SoCal
j91z28d1
it does sound like a lot. if he spent some time here it could have saved him a lot. probably just needed a afm delete cam swap and a upgraded torque converter to get what he wanted
intheburbs
SE MI
Seems kinda high.
I had the motor in my 2008 Suburban replaced by a reputable shop (read: expensive) a few years ago. Stupid oil pickup o-ring got me. GM remanufactured (3/36/100 warranty) long block was $3950, replaced all the cooler lines and high-pressure lines for the hyrdroboost, did a few other small things and the total bill was $7700.
Installing a reman 6L80/90 shouldn't be more than another $6k-$7k, so that's at most $15k.
Geotrash
Dave
Richmond, VA
Seems kinda high.
Agreed, but listed in that total was 4 new tires as well. And I would wager a bunch of other refresh items like the radiator, maybe the transfer case and such. I can see the total going up to $18K for someone else to do the job the way I would want it done if it were mine and I was trying to bring it back to as close to new as I could.
GMT800 SUV/Trucks
$18k is a lot but what has to be considered is the labor rate of the shop and the additional upgrades done for other components that were removed and not reinstalled, but had a new part installed. Fluids and additional work done for maintenance for rest of drivetrain components. On the breakdown of the $18k bill, what was the labor rate and the total hours for the job?
petethepug
petethepug
Michael
SoCal
I’m sure GM is reading that article and hoping it gets mothballed.
Ever since they switched from global architecture A to B, no modules on these trucks are cross compatible after 2015 without some major software hacking.
I’m following this upgrade from 4/6 Speed to 8/10 speed trans carefully.
Wheel bearings were replaced, too. Shop and parts rates have gone up drastically in the past few years.
Jhawk79
