Lift and rubbing
Mcanter89
Hey new here just sogned up but i recently bought a 2020 gmc yukon xl denali its being lifted with coil overs unsure of the brand but the guy doing the work who is also the owner said should be about 8.5-9” lift i i wanted 26x14 with 37s but bought a set of 26x12 with 35” tires because he said it would rub does anyone have a set up like this or can tell me if it will rub and how much cutting i will be doing ?? Ide appreciate any help
Trey Hardy
Eastern North Carolina
There’s a fella on here with a at4 who’s clearing 14 wides on 33/12.50s I don’t think you should have a issue with 35s with that big of a lift now 37s would be a different story you could probably do 37s on 12 wides but you’ll be getting into some trimming with em on 14 wides I do believe. I don’t have much experience with the new body styles but I’m just going by what I’ve seen done on here so far
Trey Hardy
Normally you just got to take a lil bit off the front bumper and pull the fender liner back on the cab side and worst case do a NorCal mod on the inner fender even lifted you wouldn’t see where it would need to be cut so I wouldn’t worry about that. But you know what they say? If you ain’t scrubbin you ain’t thuggin! lol
M
Mcanter89
Haha thank you yea i dont really mind the noise from rubbin its the noise from the passenger seat where my wife is that bothers me
M
Mcanter89
Thank you i appreciate it , yea i like the wider look but hard to find my year with this setup to really ask questions and if i do see something similar its just a picture wit no owner available ill post it up and explain what was needed to clear should be completed before christmas
M
Mcanter89
Welcome to the forum from Virginia. Post up some pictures. It’s hard to believe an 8.5” lift would rub anywhere with 35” tires but I’m no expert. @Trey Hardy may be able to help.
Hey thank you i appreciate that !! Shes going in the 2nd week of December should be done by christmas so ill definitely be posting pics and what i needed to do for others in my situation
