Wireless cell phone charger for Tahoe.
The Grey Beast
The Grey Beast
Sorry for the mish mash of photos. The video is way more explanatory. It works great I have an I Phone 15 and it has plenty of room. My phone has a case and still charges. You have to place the phone in. The middle of the charger or it doesn’t work/charge. I had to drill two holes and run the power cord from the back Consol but it all worked. My only advice is shop you screws. They don’t come with the charger. The skewers needed to screw in the top charger takes four screws when you place the power charger the length of the screws isn’t long enough and I had to make shift using old screws from around the garage. They were two long and went through the pastic. Now you put back the cover and you don’t see it and it doesn’t bother anything but it’s there. I have to cut both screws or get shorted ones to replace it. However it all works. I recommend it.
Ken
Grady_Wilson
Wyoming
Thanks for the pics and the update.
This is one project I have been wanting to do.
t_bergman
Chicago
I have to agree. I have the '17 Premier and the factory wireless charger is weak at best. The phone has to be placed perfectly and it takes forever to charge.
The 2017 was the last year to use the old tech; fairly easy to upgrade it to a 2018 wireless charging pad.
Jetskier77
Thanks for that info. Had no idea there was a better unit available. Another project to add to the list :)
bruh2125
