New 2025 Tahoe Taillights
PPV9c1
When I removed the 2021 Tail light and compared it, the plugs were surely different. I went under the vehicle hoping that further below the harness would plug, but still no. I will try to post pictures in the upcoming days.
DontTaseMeBro
I’m sure they’ll fit with a custom harness. Back in the day I retrofitted 2018+ LED tail lights onto my 2016 F-150. I made custom harnesses for them. It was super easy to do thanks to very detailed instructions written up by member of the F150 forum. Someone here has the technical chops to do this. Now all we gotta do is sit and wait.
KMeloney
Did they otherwise fit in the space in your pre-‘25? (Is it just a matter of wiring up a compatible harness?)
pa31p
Doubt it’s going to be plugn play. the light animation more than likely comes from the BCM, not the the light fixture.
DontTaseMeBro
That’s fine. Them not doing that wouldn’t bother me in the slightest. The main thing here is the aesthetic.
pa31p
Yes there’s up/down animation on start/unlock and emulation of incandesant light bulb for turn signal.(dim/bright/dim)
PPV9c1
Update:
Not to be discouraged, I contacted Gen5diy in regards to a harness to convert the 2021 wiring to 2025. Luckily, they were able to knock it out fast!
So now, I can confirm that the 2025 Base model Tail lights will work in the 2021. I'm not sure about the Uplevel 2025 tail lights, but these base models
work perfectly. I will add photos now.
Jay_Rye283
